Resolved! CME QUESTION PHONE FIRMWARE
I have seen some times that some firmware are added using extension. Loads and some times without extensions.7911 is .Loads and 7940 is without ... Why is this ??
I am attempting to upgrade our newly received 8861-3PCC phones. I have read over the forums and believe I understand the two methods: Upgrade Rule and "Browser Command" The problem I am having is that the upgrade fails in one of two ways: either the...
Hi, I want to use OPUS at 510kbps for most of my calls between sites. So it makes sense to set the system default for interregion calls, and intraregion as well for that matter, to 510Kbps. However the maximum setting is only 256K. Am I missing somet...
I have a MediaSense V11.5.1 server that I have open to the Internet for the Search and Play feature. I am using a one-to-one NAT and have TCP/8440 and TCP/8446 open. Users access the server using a FQDN and can login and scroll/search the media fil...
We are looking at upgrading our UC environment this year and the first thing I want to do is get both of our cube routers on the same hardware. I have spoken to my manager and they have approved for us to purchase 2 4431 routers to replace our 2921 r...
Hello, my apology for not posting a technical question. I'm a Avaya tech who wants to learn Cisco CUCM by building a mini CUCM home lab. I'm seeing a lot CME lab kits on Ebay however, I believe CUCM and CME are completely different from each other ...
HelloI have integrated CUCM 12.0 with CUC 12.0 using SCCP and my users can access to voice mail after introduce pin, but I want to disable this: *Option 4 related to programming options where the users can change greating, messages configuration, pre...
I am looking to change our "Dial Out" number from a "9" to a "7". To avoid ruining our current settings, I copied the existing call patterns and changed them to start with "7"; however, it seems as though this new pattern is not applying. Do I need t...
Call flows is as follows.PSTN--->Verizon SIP trunk (MPLS Ethernet)--->3750X--->CUBE (2921)--->CUCM (8.0.3 running on 1 pub and 2 subs)---->Remote routers (28xx and 29xx) -->remote switches (3xxx and 2xxx models)--->IP Phone (79xx)CUBE, CUCM, and 3750...
Hi EveryoneI was asked to block a number that is calling the head of HR everyday twice a day, I wanted to know if someone can look over my configuration and make sure this looks correct before i add this to the Cube router, and thanks in advance for ...
Hi,Running: CUCM 9.1.1, Cisco 8945G (firmware 8945.9-3-2-11).I have installed a bluetooh headset with a Cisco 8945, right now is "working" but call can't be answer if the Phones' s Headset button is not pressed so it 's not a "wireless" solution. For...
Hello I want to know if it's possible to put MoH during a conference? I know this could be sometimes annoy but for what I want to do its necessary
Hello all, looking for some help. When I'm in SRST Mode (all SIP Phones) it takes 12 seconds for the phone I want to transfer to to start ringing. I press Transfer I get dial tone right away, I dial my extension then I have to wait 12 seconds before...
We are seeing several login failures on our Exchange server at the same time every hour. The caller process name is w3wp.exe which is an IIS process. Looking at the IIS logs on our Exchange server, we are seeing log entries that mention Unity at the ...
Hello, what is the format of the activation code that should be enter when using device onboarding feature on a phone without camera. We tried with xxxx-xxxx-xxxx-xxxxxxxxxxxxxxxxxxx Nothing works Thanks
Subject | Author | Posted |
02-01-2023 09:39 PM | ||
01-25-2023 05:07 AM | ||
01-24-2023 11:30 AM | ||
01-19-2023 08:07 AM | ||
01-16-2023 05:26 PM |
User | Count |
10 | |
5 | |
4 | |
4 | |
2 |
