How to transfer all calls from the main line
Hi everyone,
I have a doubt here about why I can transfer calls that connect directly to a secondary extension (2107) but doing the same thing on the external main line (2100) this configuration does not work.
Could someone tell me where I'm going wrong?
secondary extension
ephone-dn  9  dual-line
 number 2107
 description +5511xxxx2107
 name Lucas
call-forward all 099883xxxx
main line
ephone-dn  15  octo-line
 number 2100
 description +5511xxxx2100
 name 8ito
Do you mean that the "call-forward all 099883xxxx" command can't be entered into the main line ephone-dn, or do you mean that after you enter the command the call does not forward properly?
If you mean that the call does not forward properly, are you forwarding to the same external number or a different external number? (And if it is a different number, does it work if you forward it to the same number?)
Maren
Hi Maren
Thanks for you reply,
I meant that after entering the command the call is not forwarded, but only at this primary number 2100. This is the number that people call.
I'm forwarding to a different external number. Any number does not work on the 2100.
But in the numbers 2123, 2125, 2126 ... it works. But as I said, our business number is xxxx2100.
If put this command "call-forward all 099883xxxx" the calls do not forward properly the line keeps using the ephone-hunt sequential to direct incoming calls for the local extensions.
In hunt list, I can't enter an external number.
TKS for your help.
