How to upgrade 7841 firmware
AndrewAdjei
Hello
How can I upgrade my 7841 firmware to 3pcc level
Andrew
Jaime Valencia
If you mean you have a device with enterprise FW, and you want to migrate to 3PCC, see upgrade.cisco.com
There is no "upgrade" from enterprise to 3PCC (or viceversa), that's a migration.
If you mean you have a 3PCC device and want to upgrade the FW, you need to enter the location of the FW in the upgrade rule
java
if this helps, please rate
I see so how do I migrate single device ?
Andrew
All the information is on upgrade.cisco.com, have you reviewed it??
java
Thanks for the tip and I will give it a try
