How to upload a graphic file for display on 7965 & 7970 IP phone.
ANDREA LOPEZ
Cisco Newbie Here!   Need to replace our company logo file that is displayed on some 7965 & 7970 Cisco IP phones.  How do I upload a new file and set it as the display graphic?
8 Replies 8
Payal Bhaduri
I am sending you a link and a pdf that will help you change the background image.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7965g_7945g/6_0/english/administration/guide/7965cst.html
Hope this helps.
Hello Payal,
Could you advice why i received the error message , when i want to load my Image with TFTP server please?
Could you please show me what i need to do to prevent this ?
CME-C2851(config)#tftp-server flash:Desktops/320x196x4/TN-Dak.png
File with same name already being served
CME-C2851(config)#
CME-C2851(config)#tftp-server flash:Desktops/320x196x4/Dak.png
CME-C2851(config)#tftp-server flash:Desktops/320x196x4/list.xml
CME-C2851(config)#
Can you rename the file List.xml to List123.xml and alias for what it needs to be.
eg:
tftp-server flash:List123.xml alias Desktops/320x196x4/List.xml.
You may be running into bug CSCti13845.
Hello Payal,
Thanks on  your quick response , I need to know what you mean by rename ;
Do you mean I should rename it on solarwinds TFTP server folder on my PC e.g
Change name from List.xml to List123.xml then copy it to  CME
Or
You want me to change it on CME , with command ;
tftp-server flash:/Desktops/Desktops/320x196x4/List.xml   = > to
And will i need to do that to all other files
tftp-server flash:List123.xml alias Desktops/320x196x4/Dak.png
tftp-server flash:List123.xml alias Desktops/320x196x4/TN-Dak.png
Dak
Upload as different file name, and create alias for what it needs to be.
Example:
CUCME-Alianza(config)#tftp-server flash0:Desktops/320x212x12/List1.xml alias
Desktops/320x212x12/List.xml
Remember also that we will need to change the name of the file in the flash
as well.
Example:
CUCME-Alianza#show flash
Desktops/320x212x16/List1.xml Upload as different file name, and create alias for what it needs to be.
Hello Payal,
I don't grab it at all .
Did i have to use  "tftp-server flash0:" instead tftp-server flash:
You said   -
"Remember also that we will need to change the name of the file in the flash as well "
Could you  explain how to do this ?
Best Regards,
Dak
Hello Payal,
I rund the command sugested , i have thesame issue , here is the output;
CME-C2851(config)#tftp-server flash:c7941-61/List.xml alias Desktops/320x196x4/list.xml
CME-C2851(config)#tftp-server flash:c7941-61/Jas.png alias Desktops/320x196x4/Dak.png
CME-C2851(config)#tftp-server flash:c7941-61/TN-Jas.png alias Desktops/320x196x4/TN-Dak.png
And output from show flash:
206          0 Aug 01 2011 15:44:32 Desktops
209          0 Aug 02 2011 04:29:52 Desktops/320x196x4
215      86694 Aug 02 2011 09:27:32 Desktops/320x196x4/Dak.png
216       6632 Aug 02 2011 09:28:00 Desktops/320x196x4/TN-Dak.png
217        249 Aug 02 2011 09:28:22 Desktops/320x196x4/list.xml
Thanks in Advance
Dak
Hello Payal,
I have copied them with alias, but i can not find those images on my Background Images  list
Here  is the output ;
#show run | sec tftp-server
tftp-server flash:List2011.xml alias Desktops/320x212x12/List.xml
tftp-server flash:TN-FL-DaK702011.png alias Desktops/320x212x12/TN-FL-DaK70.png
tftp-server flash:FL-DaK702011.png alias Desktops/320x212x12/FL-DaK70.png
Any Help
