06-06-2011 10:11 PM - edited 03-16-2019 05:18 AM
I have CUE 8.0.2 and i managed to configure all the thing only now AA message. By default, Cisco CUE has one greeting audio file. Can i modify that .aef file and if so, then how ?
Secondly, i have one more Cisco CUE 7.0 where someone uploaded the script for AA. Can i copy that file and upload the same into my new CUE. Do i need to change some parameter from that script in order to use in the other CUE. Thanks
06-06-2011 11:07 PM
You can edit the sample AA script that is on CUE download area. Or use ExpressEditor to create a new one.
Then load / copy scripts freely across CUEs.
For a script that does almost everything with just configuration and no editing, check universalAA on the website mentioned in my profile.
06-06-2011 11:22 PM
Please have a look on below mwntioned links,The last one will help you with the script editor.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_2/editor/scred22.html
/Gagan
Please Rate useful POSTS
06-07-2011 11:20 PM
Is there any software for configuring CUE ? Or else we can configure only by webpage.
06-07-2011 11:22 PM
You can configure either by CLI or by webpage.!!
/Gagan
