11-22-2010 08:56 PM - edited 03-16-2019 02:03 AM
We have CUCM 7.1 in HQ [ 250 users ] with MGCP Gateway and in Branch officeCUCM 7.1 [ 150 users ] with MGCP Gateway, they need to connect the HQ and Branch office via MPLS , please light me the best solution to connect both CUCM server via MPLS.
11-23-2010 07:33 AM
Please reference the CUCM SRND Multisite with Distributed Call Processing section.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/models.html#wp1043850
-Felipe
11-23-2010 08:26 AM
I agree that you need to take a look at the SRND; however, your branch site is almost the same size (in terms of users) as your HQ site. On the surface, I would order an equivalent gateway router as your main concern is going to be providing adequate SRST services in the event of an outage. So, I'll assume you're looking at a minimum of 2811 and probably more of a 2821 or higher. Is that correct? You'll want to check the SRST specs for which hardware and software versions support the number of users you'll be providing services to.
Hailey
Please rate helpful posts!
11-23-2010 08:59 PM
In HQ customer have [ CUCM 7.1 & 2821 mgcp gateway ] & in branch also they have the same setup, recently they have MPLS connection between their two site.
Now they want to make call via WAN between HQ & there Brach office, we are able to ping CUCM from HQ to branch and vice versa.
Could please give me suitable solution to make call in between two sites or do we need to go with Gatekeeper solution alone.
11-24-2010 06:53 AM
If you have connectivity between sites just configure an intercluster non-gk controlled, that's all you need.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
