Hunt Group failover in SRST
ty.masse
I have a remote location with an h.323 gateway that sends call to a hunt group in call manager under normal conditions.  I have two hunt groups.  One rings to the first 4 FXOs and the second rings to the next 4 FXOs from PSTN.
How do I create those hunt groups on the gateway itself when the system is in SRST mode so calls from the outside can reach the same phones that they would reach under normal conditions.
Thanks.
You build seperate Alias ranges, for 5552386 you would have:
alias 1 5552386 to DN1 cfw 5552386 timeout 12
alias 2 5552386 to DN2 cfw 5552386 timeout 12
alias 3 5552386 to DN3 cfw 5552386 timeout 12
alias 4 5552386 to DN4 cfw 5552386 timeout 12
for 4442356 you would continue with alias 5:
alias 5 4442356 to DN1 cfw 4442356 timeout 12
alias 6 4442356 to DN2 cfw 4442356 timeout 12
alias 7 4442356 to DN3 cfw 4442356 timeout 12
alias 8 4442356 to DN4 cfw 4442356 timeout 12
HTH,
Chris
5 Replies 5
Chris Deren
Build alias under SRST, here is an exmaple:
calls arrive to 6522 and are hunted to 4 different extensions
alias 1 6522 to 6526 cfw 6522 timeout 12
alias 2 6522 to 6525 cfw 6522 timeout 12
alias 3 6522 to 6524 cfw 6522 timeout 12
alias 4 6522 to 6523 cfw 6522 timeout 12
HTH,
Chris
Thanks for your quick reply.  Just to clarify, when a call comes in PSTN has a roll over hunt group set up which will roll to the next line if the first one is busy.  We have two sets of 4 of those.  How will your example work with calls coming in from pstn thru the voice ports?  Below is my voice port config.
voice-port 0/0/0
connection plar 4442356
description
voice-port 0/0/1
description
voice-port 0/0/2
voice-port 0/0/3
description
voice-port 0/1/0
connection plar 5552386
description
voice-port 0/1/1
description
voice-port 0/1/2
description
voice-port 0/1/3
  description
voice-port 0/0/0
description
voice-port 0/0/1
description
voice-port 0/0/2
voice-port 0/0/3
description
voice-port 0/1/0
description
voice-port 0/1/1
description
voice-port 0/1/2
description
voice-port 0/1/3
  description
HTH,
Chris
Excellent Chris.  That's awesome.  I'll configure it and give it a go.  That's one more thing in my VOIP tool bag.
Thanks.
I have similar issue  in one branch wr we have CUE . centralized with srst h323 in remote branch , where calls from pstn arrive through fxo and hit an ivr script to forward to hunt group in cucm after prompt play .
Normal condition its working fine but in srst after ivr prompt play call ends .Please advice a soultion to fix this one.
