Hunt Group - Queuing Capacity
imellor
I note that the Cisco documentation states the following:
"A single Unified CM Subscriber supports a maximum of 100 hunt pilots with call queuing enabled per node"
This raises a few questions in my mind:
1: I'm reading "node" in this context as "subscriber" so should we allow 100 per subscriber pair to allow for a failure conditions?
2: How do I balance my Hunt Groups across subscriber pairs. So for example if I have 4 x Subs in theory I can have 200 HG with queuing (allowing for failure as above), but can't see how you allocate a HG to a subscriber?
3: Does CUCM stop you configuring more than 100, or is this simply a system processing limit?
4: If it is possible to configure more than 100 / subscriber, when does it break, when the configured number reaches 100 or when over 100 Hunt Groups start queuing?
Thank you
0 Replies 0
