12-23-2020 01:34 AM
Can we from IP phone, login(Hunt Log) to different huntgroups.
We see now only one huntgroup what we can login.
Directory number is configured in two huntgroups.
12-23-2020 03:18 AM
The documentation states:
The HLog softkey allows a phone user to log a phone out of all line groups to which the phone directory numbers belong.
12-27-2020 10:54 PM
This means you login/out in all the huntgroups and not separate. Example you are in Huntgroup A and Huntgroup B configured, when you are login with your . Then you are directly in Huntgroup A and B, I was hoping you can do it separate from Huntgroup A or B.
I tested with Extension mobility and without. Must find another solution.
12-23-2020 07:14 AM
You may want to investigate extension mobility with some generic logins to accomplish this.
12-27-2020 10:55 PM
Extension Mobility same result.
12-27-2020 11:34 PM
A solution could be extension mobility with different profiles and different DN for each HG you want to login to maintaining your Main DN on all profiles.
Eg.
For HG1 you can login on profile 1 which has
DN1= Your main DN
DN2= a DN member of HG1
... and so forth
Please let me know if it could fit your needs.
BR
Carlo
01-04-2021 03:43 AM
Hi Carlo,
With different DN's in separate Huntgroups that is working. I was looking with one DN in different Huntgroups.
Br
Piet
01-04-2021 03:59 AM
