08-14-2017 01:18 AM - edited 03-17-2019 11:00 AM
Has anyone successfully got the Hunt Pilot Call Queuing working within UCCM Version 11.0, I have followed the instructions to the letter, but cannot get my Greeting to play. I can get all of the standard greetings to play without any trouble at all, but when i choose my greeting you get silence then the call gets routed to the hunt group. I have attached a few screen shots.
08-14-2017 08:28 AM
Did you upload the greeting to all servers in the cluster? The greeting is not propagated automatically. If so, try restarting TFTP and IPVMS services.
Brandon
08-15-2017 12:16 AM
I uploaded to all servers in the cluster and restarted TFTP services on all,I didnt restart IPVMS services, what impact will this have on users?
Nev
08-15-2017 12:50 AM
Did you test this with IP phones only? Meaning you dial the HP from an IP phone? Because there is an issue with using gateways
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/210537-Native-Call-Queueing-Enhancement-in-CUCM.html
JH
08-15-2017 12:53 AM
I tested IP Phones only Wired and Wireless
nev
08-15-2017 01:46 AM
Then make sure you have upload the announcement prompts on all servers. Actually, do the same procedure on all servers, although it might seem the all is correctly configured. And if you use MRGL, make sure they are assigned correct
JH
08-14-2017 10:40 AM
called party MRGL must contain the calling party Music resource
- aadhil
