Hunt Piolt
Ahmed Yassin
Dear all,
I have CCM 4.2.
I want to add new three ip phones in my three gates for my plant and i ask :
If i can make the three extensions to be Non-DID numbers and at the same time to be located in a hunt group with one hunt pilot with DID extension to be called from outside, at the same time to be called from inside the plant with its  Non-DID number.
5 Replies 5
Jaime Valencia
As long as you have the routing to reach the DNs it doesn't matter if they're DIDs or not
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Sorry, can you clarify it to me more
donovan222
You’ll need to add your Hunt pilot 1519999, Create the 3 ext 152000, 152001 and 152002 and add them to the hunt group. Add the EXT for the DID 801-555-1212 EXT: 51212 and forward it to the pilot number 1519999.
DONOVAN RAAUM
SENIOR UNIFIED COMM ENGINEER
O 763-971-2433
E Draaum@convergeone.com
Ok, thx a lot, but, how i add DID number(which will be forworded to the pilot) without phone set
Your hunt pilot can be the DID number if you want.
