I am lost.....
johncallender
HI
I have a cisco UC520 that is driving me crazy. On Friday I could access the Cisco Unified Communication Express via the web interface. Now on Monday I keep getting the error of Error: Unable to login as administrator to the Cisco CallManagerExpress at site 'local'.
Details: CME login failed
whenever I click on Configuration > extensions or phones. If I click on Users I get access. I did not perform any updates over the weekend. The directory of the flash is listed
Directory of flash:/
    1  -rw-    38008920  May 24 2031 08:26:56 -04:00  uc500-advipservicesk9-mz.1
50-1.XA2
    2  drw-           0   Apr 8 2010 14:51:40 -04:00  phones
   25  -rw-         660   Apr 8 2010 14:54:20 -04:00  vlan.dat
   26  drw-           0   Apr 8 2010 16:03:22 -04:00  ringtones
   60  -rw-        8224   Apr 8 2010 16:04:00 -04:00  -
   61  -rw-        8224   Apr 8 2010 16:04:24 -04:00  copy
   62  -rw-      409211  Aug 27 2010 12:13:10 -04:00  crashinfo_20100827-121311-
Cisco Unity Express Version 7.0
Any Ideas?
John
6 Replies 6
eramaya
Make sure you hav the ip http authentication enable in the configuration.
yes it is....
Felipe Garrido
Can you log into the CME page directly? Try going to http:///ccme.html
It doesn't look as though the CME GUI files are in flash unless they are in one of the subdirectories. can you confirm?
-Felipe
i did not see the files in the directory. Is there an easy way to add the files back?
Felipe
Thanks for the help. Sorry it took so long to get back to you, but I appreciate the sharing of knowledge.
John
