I am not able to add third person on the conference call with Ext 201
Deepak Kumar
I configured CME but I am facing the issue: I am not able to add the third person on the conference call with Ext 201:
Can you hep me?
My CME configuration as like:
Current configuration : 19947 bytes
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service password-encryption
service sequence-numbers
hostname xxxxxxxx
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 5000000
no logging console
enable secret 5 xxxxxxxxxxx
no aaa new-model
clock timezone +4GMT 4
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
voice service voip
 no notify redirect ip2ip
 srtp
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol cisco
 sip
  session transport tcp
voice class dualtone-detect-params 1
 freq-max-deviation 15
 cadence-variation 15
voice class custom-cptone UAE
 dualtone disconnect
  frequency 400 421
  cadence 400 331 239 524
voice-card 0
 dspfarm
 dsp services dspfarm
crypto pki trustpoint TP-self-signed-3059004820
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3059004820
 revocation-check none
 rsakeypair TP-self-signed-3059004820
crypto pki certificate chain TP-self-signed-3059004820
 certificate self-signed 01
  xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        quit
archive
 log config
  hidekeys
interface Loopback1
 ip address xxxxx 255.255.255.0
interface FastEthernet0/0
 ip address xxxxxxxx 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 description $ES_LAN$
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxxxxx
ip http server
ip http secure-server
tftp-server flash:cmterm-7937-sccp.1-4-1.cop
tftp-server flash:SCCP31.8-4-2S.loads
tftp-server flash:apps31.8-4-1-23.sbn
tftp-server flash:cnu31.8-4-1-23.sbn
tftp-server flash:cvm31sccp.8-4-1-23.sbn
tftp-server flash:dsp31.8-4-1-23.sbn
tftp-server flash:jar31sccp.8-4-1-23.sbn
tftp-server flash:term31.default.loads
control-plane
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone UAE
 supervisory dualtone-detect-params 1
 no battery-reversal
 disc_pi_off
 input gain 6
 output attenuation -6
 timeouts call-disconnect 1
 timeouts wait-release 1
 timing sup-disconnect 50
 connection plar opx 200
 caller-id enable
voice-port 0/0/1
 no battery-reversal
 disc_pi_off
 input gain 6
 caller-id enable
voice-port 0/0/2
 no battery-reversal
 disc_pi_off
 input gain 6
 caller-id enable
voice-port 0/0/3
 no battery-reversal
 disc_pi_off
 input gain 6
 caller-id enable
voice-port 0/1/0
 no battery-reversal
 disc_pi_off
 input gain 6
 caller-id enable
voice-port 0/1/1
 no battery-reversal
 disc_pi_off
 input gain 6
 caller-id enable
voice-port 0/1/2
 no battery-reversal
 disc_pi_off
 input gain 6
 caller-id enable
voice-port 0/1/3
 no battery-reversal
 disc_pi_off
 input gain 6
 caller-id enable
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
sccp local FastEthernet0/0
sccp ccm xxxxxxxx identifier 1 version 7.0
sccp
sccp ccm group 1
 bind interface FastEthernet0/0
 associate ccm 1 priority 1
 associate profile 1 register confdsp1
dspfarm profile 1 conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 6
 associate application SCCP
dial-peer cor custom
 name local
 name mobile
 name intl
 name internal
dial-peer cor list calllocal
 member local
dial-peer cor list callmob
 member mobile
dial-peer cor list callintl
 member intl
dial-peer cor list user
 member local
dial-peer cor list poweruser
 member local
 member mobile
dial-peer cor list superuser
 member local
 member mobile
 member intl
dial-peer cor list callintr
 member internal
dial-peer voice 1 pots
 corlist outgoing callmob
 destination-pattern 905[0256].......
 port 0/0/0
 forward-digits 10
dial-peer voice 2 pots
 port 0/0/1
 forward-digits 10
dial-peer voice 3 pots
 port 0/0/2
 forward-digits 10
dial-peer voice 4 pots
 port 0/0/3
 forward-digits 10
dial-peer voice 5 pots
 port 0/1/0
 forward-digits 10
dial-peer voice 6 pots
 port 0/1/1
 forward-digits 10
dial-peer voice 7 pots
 port 0/1/2
 forward-digits 10
dial-peer voice 8 pots
 port 0/1/3
 forward-digits 10
dial-peer voice 9 pots
 corlist outgoing calllocal
 destination-pattern 9[2-8][^0].....
 port 0/0/0
 forward-digits 7
dial-peer voice 10 pots
 port 0/0/1
 forward-digits 7
dial-peer voice 11 pots
 port 0/0/2
 forward-digits 7
dial-peer voice 12 pots
 port 0/0/3
 forward-digits 7
dial-peer voice 13 pots
 port 0/1/0
 forward-digits 7
dial-peer voice 14 pots
 port 0/1/1
 forward-digits 7
dial-peer voice 15 pots
 port 0/1/2
 forward-digits 7
dial-peer voice 16 pots
 port 0/1/3
 forward-digits 7
dial-peer voice 17 pots
 destination-pattern 90[1-4,6-9].......
 port 0/0/0
 forward-digits 9
dial-peer voice 18 pots
 port 0/0/1
 forward-digits 9
dial-peer voice 19 pots
 port 0/0/2
 forward-digits 9
dial-peer voice 20 pots
 port 0/0/3
 forward-digits 9
dial-peer voice 21 pots
 port 0/1/0
 forward-digits 9
dial-peer voice 22 pots
 port 0/1/1
 forward-digits 9
dial-peer voice 23 pots
 port 0/1/2
 forward-digits 9
dial-peer voice 24 pots
 port 0/1/3
 forward-digits 9
dial-peer voice 25 pots
 corlist outgoing callintl
 destination-pattern 900T
 port 0/0/0
 prefix 00
dial-peer voice 26 pots
 port 0/0/1
 prefix 00
dial-peer voice 27 pots
 port 0/0/2
 prefix 00
dial-peer voice 28 pots
 port 0/0/3
 prefix 00
dial-peer voice 29 pots
 port 0/1/0
 prefix 00
dial-peer voice 30 pots
 port 0/1/1
 prefix 00
dial-peer voice 31 pots
 port 0/1/2
 prefix 00
dial-peer voice 32 pots
 port 0/1/3
 prefix 00
dial-peer voice 33 pots
 destination-pattern 9[19]..
 port 0/0/0
 forward-digits 3
dial-peer voice 34 pots
 port 0/0/1
 forward-digits 3
dial-peer voice 35 pots
 port 0/0/2
 forward-digits 3
dial-peer voice 36 pots
 port 0/0/3
 forward-digits 3
dial-peer voice 37 pots
 port 0/1/0
 forward-digits 3
dial-peer voice 38 pots
 port 0/1/1
 forward-digits 3
dial-peer voice 39 pots
 port 0/1/2
 forward-digits 3
dial-peer voice 40 pots
 port 0/1/3
 forward-digits 3
dial-peer voice 41 pots
 destination-pattern 9800T
 port 0/0/0
 prefix 800
dial-peer voice 42 pots
 port 0/0/1
 prefix 800
dial-peer voice 43 pots
 port 0/0/2
 prefix 800
dial-peer voice 44 pots
 port 0/0/3
 prefix 800
dial-peer voice 45 pots
 port 0/1/0
 prefix 800
dial-peer voice 46 pots
 port 0/1/1
 prefix 800
dial-peer voice 47 pots
 port 0/1/2
 prefix 800
dial-peer voice 48 pots
 port 0/1/3
 prefix 800
dial-peer voice 49 pots
 destination-pattern 9600T
 port 0/0/0
 prefix 600
dial-peer voice 50 pots
 port 0/0/1
 prefix 600
dial-peer voice 51 pots
 port 0/0/2
 prefix 600
dial-peer voice 52 pots
 port 0/0/3
 prefix 600
dial-peer voice 53 pots
 port 0/1/0
 prefix 600
dial-peer voice 54 pots
 port 0/1/1
 prefix 600
dial-peer voice 55 pots
 port 0/1/2
 prefix 600
dial-peer voice 56 pots
 port 0/1/3
 prefix 600
dial-peer voice 57 pots
 destination-pattern 95......
 port 0/0/0
 forward-digits 7
dial-peer voice 58 pots
 port 0/0/1
 forward-digits 7
dial-peer voice 59 pots
 port 0/0/2
 forward-digits 7
dial-peer voice 60 pots
 port 0/0/3
 forward-digits 7
dial-peer voice 61 pots
 port 0/1/0
 forward-digits 7
dial-peer voice 62 pots
 port 0/1/1
 forward-digits 7
dial-peer voice 63 pots
 port 0/1/2
 forward-digits 7
dial-peer voice 64 pots
 port 0/1/3
 forward-digits 7
dial-peer voice 999 voip
 description **xxxxxxx**
 destination-pattern 888
 session protocol sipv2
 session target ipv4:xxxxxx
 dtmf-relay rtp-nte sip-notify sip-kpml
 codec g711ulaw
 no vad
sip-ua
 retry options 1
telephony-service
 sdspfarm units 5
 sdspfarm tag 1 confdsp1
 max-ephones 35
 max-dn 35
 ip source-address 192.168.101.253 port 2000
 auto assign 1 to 35
 system message Bashayer
 cnf-file perphone
 load 7931 SCCP31.8-4-2S.loads
 load 7937 cmterm-7937-sccp.1-4-1.cop
 time-zone 35
 voicemail 888
 max-conferences 8 gain -6
 moh music-on-hold.au
 web admin system name admin secret 5 xxxxxxxxxxxx
 dn-webedit
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  10
 conference admin
 softkeys hold  Join Newcall Resume Select
 softkeys idle  Cfwdall ConfList Dnd Gpickup HLog Join Login Newcall Pickup Redial RmLstC
 softkeys seized  Callback Cfwdall Endcall Gpickup HLog Meetme Pickup Redial
 softkeys connected  Acct ConfList Confrn Endcall Flash HLog Hold Join LiveRcd Park RmLstC Select TrnsfVM Trnsfer
 button-layout 7931 2
ephone-template  20
ephone-dn  1  dual-line
 number 200
 corlist incoming superuser
ephone-dn  2  octo-line
 number 201
ephone-dn  3  dual-line
 number 202
 corlist incoming poweruser
ephone-dn  4  dual-line
 number 203
 label 203
 name 203
 call-forward noan 888 timeout 10
ephone-dn  5
 number 204
 label 204
 name 204
 hold-alert 30 originator
ephone-dn  6  dual-line
 number 205
 label 205
 name 205
ephone-dn  7  dual-line
 number 206
 call-forward noan 888 timeout 15
ephone-dn  8  dual-line
 number 207
ephone-dn  9  dual-line
 number 208
ephone-dn  10  dual-line
 number 209
ephone-dn  11  dual-line
 number 210
ephone-dn  12  dual-line
 number 211
ephone-dn  13  dual-line
 number 212
 corlist incoming user
ephone-dn  14  dual-line
 number 213
ephone-dn  15  dual-line
 number 214
ephone-dn  16  dual-line
 number 215
ephone-dn  17  dual-line
 number 216
ephone-dn  18  dual-line
 number 217
ephone-dn  19  dual-line
 number 218
ephone-dn  20  dual-line
 number 219
ephone-dn  21  dual-line
 number 220
ephone-dn  22  dual-line
 number 221
ephone-dn  23  dual-line
 number 222
ephone-dn  24  dual-line
 number 223
ephone-dn  25  dual-line
 number 224
ephone-dn  26  dual-line
 number 225
ephone-dn  27  dual-line
 number 226
ephone-dn  28  dual-line
 number 227
ephone-dn  29  dual-line
 number 228
ephone-dn  30  dual-line
 number A3089
 conference ad-hoc
 no huntstop
ephone-dn  31  dual-line
 number A3089
 conference ad-hoc
 no huntstop
ephone-dn  32  dual-line
 number A3089
 conference ad-hoc
 no huntstop
ephone-dn  33  dual-line
 number A3089
 conference ad-hoc
 no huntstop
ephone-dn  34  dual-line
 number 233
ephone-dn  35  dual-line
 number 234
 label Kitchen
 name Kitchen
 call-forward noan 888 timeout 18
ephone  1
 device-security-mode none
 mac-address xxxx
 ephone-template 20
 after-hours exempt
 username "200" password 200
 type 7931
 button  1:1
ephone  2
 mac-address xxxx
 type 7931
 button  1:11
ephone  3
 mac-address xxxx
 after-hours exempt
 type 7942
 button  1:23
ephone  4
 mac-address xxxxx
 type 7942
 button  1:6
ephone  5
 mac-address xxxx
 type 7942
 button  1:4
ephone  6
 mac-address xxxx
 type 7942
 button  1:5
ephone  7
 mac-address xxxx
 type 7942
 button  1:7
ephone  8
 mac-address xxxx
 type 7942
 button  1:8
ephone  9
 mac-address xxxx
 type 7942
 button  1:9
ephone  10
 mac-address xxxx
 type 7942
 button  1:12
ephone  11
 mac-address xxxxx
 username "211" password 211
 type 7942
 button  1:10
ephone  12
 mac-address xxxxx
 type 7911
 button  1:13
ephone  13
 mac-address xxxxx
 type 7942
 button  1:3
ephone  14
 mac-address xxxxxx
 type 7937
 button  1:2
line con 0
 password 7 xxxxx
 login
line aux 0
line vty 0 4
 password 7 xxxxxx
 login
line vty 5 15
 password 7 xxxxx
 login
scheduler allocate 20000 1000
end
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Rajan
Hi Deepak,
Can you check whether the configured conference bridge is up and try adding the below command under telephony-service:
telephony-service
conference hardware
Rajan
Dual line is working fine but octa line is not working.
Deepak Kumar
Deepak Kumar,
Can you add these for that dn:
conference ad-hoc
no huntstop
Rajan
