I need CUCM 8.0.2.40000-1 ISO
alberto.douglas
hi,
Im doing an upgrade from
8.0.2.40000-1 to 8.5. I need to upgrade this to a VMWare so I would like to know if someone has the bootable ISO for 8.0.2.40000-1. Since the one I found on cisco is only for upgrades.
thanks!
Jaime Valencia
Bootable media is not available for download.
You can get this by reaching Cisco either directly via your SE, a Partner or PUT.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
thanks man
i will try your advise
thanks!
If you're upgrading from MCS to VMWare, you can always build it with the 8.0.2 image you have in VMWare using the bootable media you should have, and then upgrade using the non bootable media off of CCO.
However, keep in mind that just because you can get the media doesn't mean it's going to work.  Often times these upgrades required software feature licenses that can only be obtained via PUT or purchase.
Cliff
