10-27-2015 10:06 AM - edited 03-17-2019 04:43 AM
Hello Team,
Please I need help with my installation. I am setting up a CME V10 IPT
I have a DID range of 80380553xx to 350
When my phones make external (PSTN) calls, they all use the same line 8038055300 instead of their individual numbers. Example. extension 305 should call with 8038055305.
Secondly inbound calls are not reaching the extensions, I always get the message "The number you are calling is not allocated"; but from debug voip dial-peer, I can see that the calls from PSTN are reaching my gateway.
Anthony
Solved! Go to Solution.
10-27-2015 11:10 AM
Hello Anthony,
for incoming call you don't outbound dial-peer matching to called and calling number that's why your calls is failing and for outbound call can you please send the output of
show dial-peer voice summary and also make another outbound test call enable below debugs
Debug isdn q931
debug voice ccapi inout
in last log we see we are sending out the call from VGW to PSTN with below number by matching dial-peer voice 2 pots .
Oct 27 18:15:46: //163/30A6A70A818C/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x230DE4B0, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=301,(Calling Name=Fabio Gomez)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=07057023846(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=2, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Oct 27 18:15:46: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct 27 18:15:46: :cc_get_feature_vsa malloc success
Oct 27 18:15:46: cc_get_feature_vsa count is 2
Oct 27 18:15:46: :FEATURE_VSA attributes are: feature_name:0,feature_time:553910608,feature_id:144
Oct 27 18:15:46: //164/30A6A70A818C/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Oct 27 18:15:46: //164/30A6A70A818C/CCAPI/ccCallSetContext:
Context=0x3EEA0BD4
Oct 27 18:15:46: //163/30A6A70A818C/CCAPI/ccSaveDialpeerTag:
calling num: 301
called number:07057023846.
you need to make for incoming and outgoing what number needs to be translated and what number is being expected by TELCO . correct the same on VGW by creating translation rule and pattern or on CUCM.
Also i see a translation rule configuration in the VGW config but this is incomplete one. you need to apply on calling or called which is not there.
voice translation-rule 1
rule 1 /8038055\(3..\)/ /\1/
voice-port 0/0/0:15
translation-profile incoming PSTN
Br,
nadeem ahmed
