11-29-2010 06:47 AM - edited 03-16-2019 02:09 AM
hello
i need your help to test the fax over ip
s started with T37 FOIP in my lab ,i used a router cisco 2801.
So I configure my router using onramp and offramp script .
in the test
from the fax machine to email work fine without a problem
the problem if i send an email from Outlook to fax machine i get this erreur
Delivery was unsuccessful to the following recipient(s):
<fax=71891226@fax.xxxxx>
Failed with the status of: 450 4.4.2 Modem timed out
The cause code is: no user answer (19)
The fax error text is: no user answer (19): No answer T30 timeout
i test every think but dosen't work.
this is my router config
fax#sh run
Building configuration...
Current configuration : 2844 bytes
! Last configuration change at 11:09:27 GMT Mon Nov 29 2010
version 15.1
hostname fax
boot-start-marker
boot-end-marker
enable secret 5 $1$FW2N$M3Dd8klY1SefZSa6XCTsa.
enable password gss
no aaa new-model
clock timezone GMT 1
dot11 syslog
ip source-route
ip cef
ip domain name xxxxx
ip name-server 192.168.1.100
no ipv6 cef
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice-card 0
fax send transmitting-subscriber $s$
fax send left-header $t$
fax send center-header $s$
fax send right-header $p$
fax send coverpage enable
fax send coverpage show-detail
fax send coverpage comment vdtl-5350-8a Offramp Cover Page
fax interface-type fax-mail
mta send server 192.168.1.104 port 25
mta send origin-prefix "Cisco-powered Fax System"
mta send postmaster borhen.bouallagui@xxxxx
mta send mail-from hostname xxxxx
mta send mail-from username Administrateur
mta receive aliases 192.168.1.104
mta receive aliases fax.gss.local
mta receive maximum-recipients 100
application
service onramp flash:app_faxmail_onramp.2.0.1.3.tcl
service offramp flash:app_faxmail_offramp.2.0.1.1.tcl
call-history-mib retain-timer 500
call-history-mib max-size 500
license udi pid CISCO2801 sn FCZ1410C1A8
redundancy
interface FastEthernet0/0
ip address 192.168.1.251 255.255.255.0
speed auto
full-duplex
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip pim bidir-enable
ip route 0.0.0.0 0.0.0.0 192.168.1.1
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol dec
voice-port 0/3/0
voice-port 0/3/1
connection plar 71891326
voice-port 0/3/2
voice-port 0/3/3
dial-peer voice 71 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 71891326
information-type fax
session target mailto:borhen.bouallagui@xxxxx
incoming called-number 71891326
mdn
dsn success
dsn failure
dial-peer voice 72 pots
service onramp
incoming called-number 7.......
direct-inward-dial
port 0/3/1
dial-peer voice 73 pots
destination-pattern .T
direct-inward-dial
port 0/3/1
forward-digits all
dial-peer voice 774 mmoip
service offramp
incoming called-number .T
image encoding MH
image resolution standard
mdn
gateway
timer receive-rtp 2100
telephony-service
max-conferences 4 gain -6
transfer-system full-consult
line con 0
line aux 0
line vty 0 4
password gss
login
transport input all
scheduler allocate 20000 1000
end!
and this sh ver output
fax#sh ver
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 15.1(1)T, R ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Mar-10 02:02 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
fax uptime is 54 minutes
System image file is "flash:c2801-advipservicesk9-mz.151-1.T.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2801 (revision 7.0) with 359424K/33792K bytes of memory.
Processor board ID FCZ1410C1A8
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
1 DSP, 16 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
126000K bytes of ATA CompactFlash (Read/Write)
pls i need your help to do this .
thx
11-29-2010 10:00 AM
Can you collect the following debug output for a failed call.
debug voip ccapi inout
debug vpm signal
Please note the called party number.
-Felipe
12-03-2010 05:58 AM
