12-07-2012 11:02 AM - edited 03-16-2019 02:36 PM
Hi All,
I have a problem where users are getting calls on their IP phones saying 911. These are coming from the analog lines located on the FXO ports installed on their 3825 that we use to route 911 calls. I ran a debug (debug voice ccapi inout) and can see when the call comes in but I dont see what the number is that is dialing it. Is it possible to see what number is calling into these FXO ports and if so what command should I run to log it or just watch it?
Its a 3825 with a VIC2-4FX0 running IOS 12.4(24) T2.
12-07-2012 01:28 PM
If you dial those lines does the caller ID still show 911? If not then the people calling into those lines are spoofing their caller ID as 911. Some areas do allow a person so send anything they want out as caller ID, like where I work.
Tracy
12-07-2012 01:39 PM
You have a "dial-peer voice 911 pots", and some bug (can't find details) make that is erroneously shown as calling number.
Update IOS.
12-07-2012 02:06 PM
So if I update the IOS I will be able to see what number is calling into my POTS lines by debugging the router?
Thanks!
12-07-2012 02:13 PM
Router is not getting any CLID otherwise it would show it. "debug vpm signal" with "term mon".
12-11-2012 02:07 PM
Well that gave me a little more information. It appears the calls that were coming in via those analog lines has stopped. I appreciate all the feed back.
