identify mute event in phone console log
Jeff G
I'm looking for a way to identify when a call is placed on and off mute, primarily on a 7841 running 11-7-1-17.  Mute is a local function to the phone, so CDR is out.  Thread 3310268 tells me it should be in the console log, and that lines up with what I thought, but I'll be hanged if I can find the event entry.  Can anyone toss me a clue?
Aeby Vinod
Level 3
Level 3
The message on console logs varies by phone models. If you can put a call on mute, unmute it,note the time and attach the console logs here, I can help you out on finding the message or line which denotes when the call was put on mute.
Please rate if you find this helpful.
Aeby
Aeby
