Unity Connection Error " Out of memory "
aslam.bajwa
Level 3
Level 3
Hello ,
we have unity connection 6.1.1.2000 - 3 , we are facing unity error " Out of memory"   so frequently , when problem comes we are unable to Access untiy through web and CLI . hard reboot of the unity server is fixing this issue for some time.
please advise .
regards
Aslam
11 Replies 11
Jaime Valencia
What platform are you running this on and are you following the guidelines for the sizing recommendations (users, VM ports, IMAP sessions, etc)??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
hello ,
Platform is MCS 7816 i3 , could you tell me the recomending sizing ?? , i guess this the issue. because i have the following issues befor restarting the server :
out of memory : killed process 528 tomcat
out of memory : killed process 2117 tomcat
out of memmory : killed process 7250 tracecollection
out of memmory : killed process 7578 Java
regards ,
Did you find a solution?
Hi Mohamed,
Are you running the same 6.x version , MCS server model and facing the same issue?
Manish
Hi Manish,
we are running the Version 8.6.2.20000-76 and facing the issue as you can see here:
The server always runs into memory problems and goes down from time to time.
Best regards
Mohamed
Please make sure that the RAM, CPU and HDD settings are as per the 8.6 version. You should get the outputs of the following commands from the server to check for any errors / core dumps
utils diagnose test
utils core active list
If the issue persists after a reboot then get the Perfmon logs as well and contact TAC.
Manish
RAM, CPU and HDD is ok.
The commands show the following output.
Ok then, I will contact Cisco TAC.
Thank you very much
The outputs look good, no issues there. Yes, contacting TAC will help. They will require the traces / logs corresponding to the alerts, if the alerts are frequent then they should be able to get the required info easily.
Manish
Ok thank you very much for your fast help.
Hi Mohamed,
What was the fix in the end of it all?
Dear teams,
Did you fix in the end of it all?
Thank you and best regards,
John Phan.
- Cisco Webex Teams Ambassador.
- Telco Expert.
- Collaboration Engineer.
- Contact Center Specialist.
- CCIE Collaboration Written.
Skype: duong.phanthai
Mobile: +84909495658
https://www.linkedin.com/in/thai-duong-phan-5819549b
Best regards,
John Duong Phan
