Identify Transcoder resource use DETAILS?
ajenks
I am shortly retiring a gateway that has transcoder resources configured (it is no longer doing any PSTN termination). I did not want to remove it from MRL's until I was sure it was no longer being used. I set an alert in RTMT and have been running this for almost 2 weeks. Today I got an alert that the resource was in use (for the first time since monitoring). By the time I connected to the device to investigat, the xcode was no longer active.
Is there a way (from CM (7.x) logging or other) that I can determine any details around how/why this was invoked (endpoints involved etc.) historically? - this would be my ideal scenario as it appears to be used vary rarely, or, what debugging do I need to configure to enable collection of this information for future event? I have enabled "debug dsp events" - is this sufficient? "debug media resource provisioning" is not supported on this hardware (I think this may have worked?) - It's a X4604 running 12.4 running as h323 gateway.
Any help would be greatly appreciated.
Payal Bhaduri
The detailed cucm traces for that period is sufficient to determine why the transcoder was invoked. It will also show the codec negotiation.
