Implementation Planning
Siva chinap
Level 5
Level 5
If i have requirement of 20k users,in which there are 10k CUC & IM users,,,which hardware i can go for UCS-C series or B-series,can i install all the servers in a single box?
assivasu
Yes a virtual server can be forced to take advantage of our products even better than the original message and occasion making it easy
My question is about hardware specifications?
I'd strongly recommend you to either reach pre-sales if you're a partner, or to reach a Gold Partner for a quote. If you're not a partner, you won't be doing any buying by yourself anyway, and you'll get proper advice taking into consideration all factors that need to be accounted for this.
java
if this helps, please rate
As enterprise design,how will u design,just give me a rough idea about this specification!!
