Import Translation patterns
shane.oconnell
Need to do a bulk import of tranlsation patterns but have never done this before and do not want to end up deleting any existing tp's.
Do I need to export ALL the tp's then add the new tp's and then import all of them together again? Or do I just import the tp's that I want to create?
Is there any danger of erasing existing translation patterns using the import tool?
Chris Deren
You only need to import new ones, it will not overwrite existing ones.
Chris
