09-05-2015 10:03 AM - edited 03-17-2019 04:14 AM
09-05-2015 11:44 AM
Are you referring to DTMF relay? In this case go through this URL.
https://supportforums.cisco.com/blog/154706
09-05-2015 11:44 AM
09-05-2015 02:30 PM
inbound and outbound generally refers the direction of a call whether it is a sip or pots , if you want to understand think yourself as a router , anything coming to you is considered as inbound any call going from you is considered as outbound.
i hope you understand
09-05-2015 06:27 PM
Hi massacred,
Thanks for your feedback , I know the concept of inbound and outbound but wanna know more about the In-band and Out-band with SIP protocol
Vinod
09-05-2015 06:31 PM
Hi Mohammed ,
Yes you are correct I'm referring the DTMF relay ,please can you elaborate more about the difference between the In-band and out of band concept ?
Thanks ,
Vinod.
09-05-2015 08:09 PM
Inband carries DTMF traffic part of the media stream. Now depending on the type of inband (RTP-NTE or Inband Voice), the Payload Type (PT) value in RTP header will change.
Outband carries DTMF signaling using the call signaling protocol (SIP, H323, MGCP) which is separate from media stream.
This is at concept level. Now you can dive deeper in each protocol. I shared the URL for SIP. Here are other URLs for other protocols.
http://x-ccie.blogspot.ae/2012/02/h323-dtmf-relay.html
http://x-ccie.blogspot.ae/2012/02/mgcp-dtmf-relay.html
