In-Room Control Functions
Chris Brumley
I am running a couple of rear monitors off the output 3 connection on a MX800 Dual. I've read through the guides and it looks like I am able to add a panel to the Touch 10 that would allow for swapping of the monitor roles on those monitors but I have been unsuccessful. I am just curious if anyone has done this or know if this is possible. I am including the code incase you notice if I have something out of place or if you just tell me this will not work.
<Extensions>
  <Version>1.2</Version>
  <Panel>
    <Icon>Input</Icon>
    <Type>InCall</Type>
    <Page>
      <Name>Rear Monitor</Name>
      <Row>
        <Name>Rear Monitor Control</Name>
        <Widget>
          <WidgetId>Local View</WidgetId>
          <Type>Button</Type>
          <Name>Local View</Name>
          <Options>size=2</Options>
    <Configuration>
   <Video>
    <Output>
     <Connector item="3">
      <MonitorRole>First</MonitorRole>
     </Connector>
    </Output>
   </Video>
  </Configuration>
        </Widget>
        <Widget>
          <WidgetId>Remote View</WidgetId>
          <Type>Button</Type>
          <Name>Remote View</Name>
    <Configuration>
   <Video>
    <Output>
      <MonitorRole>Second</MonitorRole>
     </Connector>
    </Output>
   </Video>
  </Configuration>
        </Widget>
      </Row>
    </Page>
  </Panel>
</Extensions>
keglass
Level 7
Level 7
Hi, Chris,
I recommend you also post this to the Cisco Support Community for additional feedback and information from other users and technical experts.
https://supportforums.cisco.com/
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
