Hi Lim,
This mean when the pstn party close the line,the fxo isn't awaring for that
Confirm this after closing the pstn line and check on the gateway that the fxo still up
then you need some configuration to your fxo port as "supervisory disconnect"
Another low suggested point that the fxo is allready down,so you can start checking inside your network
wish this be helpful
