IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6331 Views
  • 14 replies
I have a 2801 with a PRI and 2 Fast Ethernet interfaces. We want to dual-home the gateway to separate core switches, with one Fast Ethernet interface to each switch.My question is what is the best way to do this? I was thinking of putting both inte...
degg by Level 1
  • 1300 Views
  • 4 replies
CUCM 6.1.4when an analog phone is on a call (thru an ATA adapter), and the other party goes on-hook, the call ends, as expected.  However, the analog phone gets a second dial tone and a fast busy immediately after the call disconnects.any ideas?
francisg by Level 1
  • 402 Views
  • 1 replies
Hi,I'm struggling to work out when I would need CUBE, and when I would use just gatekeeper.The first scenario is to join 3 CCM Clusters (and upto 5 or 6 later on).Later on we may implement a SIP Trunk to the Telco.At what point do I need CUBE?Thanks.
simmo by Level 1
  • 1086 Views
  • 3 replies
Hi everyone,having a cluster issue and it seems to be indirectly pointing to something with the call manager service.This is the scenario;1. I have multiple locations with Metro WAN connections of 4MB or more.2. We have Four CUCM 6.1.2 servers - 1 pu...
a.gooding by Level 5
  • 7118 Views
  • 24 replies
Hello,I am having trouble with CME in SRST mode. This si my config :telephony-service srst mode auto-provision all max-ephones 5 max-dn 5 preference 9 ip source-address 10.10.32.3 port 2000 mwi relay max-conferences 8 gain -6 web admin system name ad...
Hi,I need a small help in Call Handler design....Whenevr someone calls to Board number, call lands to the Call Handler where it should play a message like below:"Welcome to Test. Kindly press "0" to reach to the Reception or Dial the Required Extensi...
