07-31-2018 06:10 AM - edited 03-18-2019 12:28 PM
Can anyone point me to a good document on inbound call routing?
Also, if you have any other thoughts on the scenerio below, would be appreciated.
We are adding another number to our circuit and I'm trying to figure out how to get it to route.
Today we receive 10 digits from the telco:
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
Translate them to 3 or 4 digits
voice translation-rule 1 (bogus numbers used here)
rule 1 /^1234567\(...\)$/ /\1/
rule 2 /^2234567\(...\)$/ /\1/
rule 3 /^3234567\(...\)$/ /\1/
rule 4 /^4234567\(...\)$/ /\1/
rule 5 /^5234567\(...\)$/ /\1/
rule 6 /^6123456\(5...\)$/ /\1/
rule 7 /^712345\(9...\)$/ /\1/
rule 8 /^723456\(4...\)$/ /\1/
rule 9 /^733456\(6...\)$/ /\1/
rule 10 /^743456\(...\)$/ /\1/
rule 11 /^753456\(1...\)$/ /\1/
voice translation-profile DID
translate called 1
Send them to Call Manager
dial-peer voice 1113 voip
preference 2
destination-pattern [0-9]...$
session target ipv4:10.X.14.11
incoming called-number 9T
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric h245-signal
fax-relay ecm disable
fax rate 14400
ip qos dscp cs3 signaling
no vad
dial-peer voice 11131 voip
preference 10
destination-pattern [0-9]..$
session target ipv4:10.X.14.10
voice-class codec 1
voice-class h323 1
fax rate 14400
no vad
dial-peer voice 11132 voip
preference 1
session target ipv4:10.X.25.11
voice-class codec 1
voice-class h323 1
fax rate 14400
no vad
dial-peer voice 111322 voip
tone ringback alert-no-PI
preference 1
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind connect enable 8
voice-class codec 1
voice-class h323 1
dtmf-relay h245-signal h245-alphanumeric
no vad
dial-peer voice 111311 voip
preference 5
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 11133 voip
preference 2
voice-class codec 1
voice-class h323 1
no vad
CUCM then has a translation pattern
21xxx that points to endpoint or
219441 (and others such as)
Since the new number had overlapping last 4 digits, I tried adding a translation rule for 6 digits
rule 12 /^4235\(......\)$/ /\1/
adding an additional dial-peer to CUCM
dial-peer voice 11134 voip
preference 10
destination-pattern [0-9].....$
voice-class codec 1
voice-class h323 1
no vad
And a translation pattern in CUCM for the last 6 digits
123456
However I get Cause i = 0x8081 - Unallocated/unassigned number
07-31-2018 06:15 AM
07-31-2018 06:35 AM
voice-port 1/0:23
translation-profile incoming DID
voice-port 1/1:23
The 3 and 4 digit translations are not the problem. They route fine. it's when I tried adding the new number with the 6 digit translation. I posted those at the end of my first post.
07-31-2018 06:39 AM
07-31-2018 08:35 AM
I can send those debugs as I was testing with the telco previously.
Ok, Guess that is going to be a problem since the 4 digit conflicts with another number. -Thanks
