02-14-2013 01:57 PM - edited 03-16-2019 03:43 PM
I have a 2801 and have CME up and running. All is fine for the most part. I can make outbound calls through my SIP provider all day long. Inbound not so much luck. I am running 15.1 and ran across the toll fraud stuff and thought I had found my problem. Unfortunately even after adding my SP's IP's to the trusted list I still get no love. Call just goes to dead air. Service provider shows them sending two invites but they get nada from me.
What am I missing? My understanding is that 5060 is open by default. Only thing I can think is that my external interface is just dropping the traffic.
Here is my config. I would really appreciate any insight anyone has. Always good to have another set of eyes to catch what should be staring me right in the face.
Thanks in advance.
Joel
! Last configuration change at 21:54:07 UTC Thu Feb 14 2013 by joel
version 15.1
service password-encryption
hostname Kappes_2801
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain lookup source-interface FastEthernet0/1
no ipv6 cef
voice service voip
ip address trusted list
ipv4 60.23.129.253
ipv4 66.23.138.162
ipv4 66.23.190.100
ipv4 66.23.190.200
allow-connections sip to sip
redirect ip2ip
sip
registrar server
voice class codec 1
codec preference 1 g711ulaw
voice translation-rule 1
rule 1 /13036475930/ /2000/
rule 2 /3036475930/ /2000/
voice translation-profile Incoming_called_numbers
translate called 1
voice-card 0
license udi pid CISCO2801 sn FTX1008W1XQ
username joel privilege 15 password 7 15010E1C142B20707B636C
redundancy
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
description Internal Data Network (Native VLAN)
encapsulation dot1Q 1 native
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0.2
description Cisco Voice Network
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface FastEthernet0/0.3
description ShoreTel Switches and Phones Network
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
ip helper-address 192.168.1.253
ip nat inside
ip address 50.78.80.57 255.255.255.252
ip nat outside
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/2/0
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:gui
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source list 2 interface FastEthernet0/1 overload
ip nat inside source list 3 interface FastEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 50.78.80.58
logging esm config
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 3 permit 192.168.2.0 0.0.0.255
control-plane
voice-port 0/0/0
voice-port 0/0/1
dial-peer voice 100 voip
description OUTGOING SIP TRUNK CONNECTION
destination-pattern 1..........
session protocol sipv2
session target dns:px3.nexvortex.com
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
description INCOMING SIP CALL FROM SIP TRUNK
incoming called-number ..........
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
authentication username gk10126HzMG password 7 023F336F311218224F7C
nat symmetric role active
nat symmetric check-media-src
no remote-party-id
registrar dns:reg.nexvortex.com expires 3600
sip-server dns:px3.nexvortex.com
gatekeeper
shutdown
telephony-service
max-ephones 2
max-dn 2
ip source-address 192.168.2.1 port 2000
auto assign 1 to 2
voicemail 2500
max-conferences 4 gain -6
web admin system name joel password seppak4309
dn-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 2000
label Joel#1
name Joel Kappes
call-forward busy 2500
call-forward noan 2500 timeout 18
ephone-dn 2 dual-line
number 2001
label Joel#2
name Joel Kappes
ephone 1
no multicast-moh
device-security-mode none
mac-address 0014.A971.44D7
type 7960
button 1:1
ephone 2
no multicast-moh
mac-address 0014.A934.0A48
type 7960
button 1:2
line con 0
line aux 0
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
ntp server 192.168.1.253
end
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice service voip
ipv4 60.23.129.253
ipv4 66.23.138.162
ipv4 66.23.190.100
ipv4 66.23.190.200
redirect ip2ip
sip
registrar server
voice class codec 1
translate called 1
voice-card 0
redundancy
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat inside
ip nat outside
duplex auto
speed auto
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
ip http server
logging esm config
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
no remote-party-id
gatekeeper
shutdown
telephony-service
max-ephones 2
max-dn 2
auto assign 1 to 2
voicemail 2500
web admin system name joel password #%#$%
dn-webedit
number 2000
label Joel#1
name Joel Kappes
number 2001
label Joel#2
name Joel Kappes
ephone 1
no multicast-moh
type 7960
button 1:1
ephone 2
no multicast-moh
type 7960
button 1:2
line con 0
line aux 0
line vty 0 4
login local
transport input all
end
02-14-2013 04:32 PM
Post "debug ccsip messages".
Chris
