Inbound calls via SIP carrier not working
jamieparr
Hi guys
We have a new setup of SP > CUBE > CM. Outbound calling works fine, audio both ways. External callers inbound get dead air when they dial in, no ring back, although the phone does ring and can be answered. The phone itself is showing no recvd packets.
SIP trace below, can anyone see anything wrong?
JP
*Jun 29 14:58:06.892: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:+358XXXXXXXX@193.64.250.10;user=phone SIP/2.0
Via: SIP/2.0/UDP 194.157.170.75:5060;branch=z9hG4bKj8puld1088k33ap77930.1
Content-Length: 290
From: <sip:+491XXXXXXXX@194.157.170.75;user=phone>;tag=SDf2tj501-VA91cB22heXghW0Y
To: <sip:+358XXXXXXXX@193.64.250.10;user=phone>
Call-ID: SDf2tj501-40f1f41a1fe8a07075315b070597e20b100@sbc.ngn.fi
CSeq: 1 INVITE
Max-Forwards: 69
Request-Disposition: no-fork
Session-Expires: 1800;refresher=uac
Contact: <sip:194.157.170.75:5060;yop=00.00.37B34070.0000.4250;realip=139.97.234.132;transport=udp>
Supported: 100rel,timer,norefersub
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,UPDATE
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=- 0 0 IN IP4 194.157.170.75
s=-
c=IN IP4 194.157.170.75
t=0 0
m=audio 16602 RTP/AVP 8 0 18 13 101
b=AS:80
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:13 CN/8000
a=rtpmap:101 telephone-event/8000
a=ptime:20
a=maxptime:20
*Jun 29 14:58:06.894: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
*Jun 29 14:58:06.894: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:7FA352F2E368
*Jun 29 14:58:06.894: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:uac, Min-SE Value:1800, flags:2001
*Jun 29 14:58:06.896: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Jun 29 14:58:06.896: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:7FA352F2B448
*Jun 29 14:58:06.897: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
*Jun 29 14:58:06.899: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
*Jun 29 14:58:06.900: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
*Jun 29 14:58:06.901: //64/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
*Jun 29 14:58:06.901: //64/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:7FA352F2E160
*Jun 29 14:58:06.901: //64/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:uac, Min-SE Value:1800, flags:2001
*Jun 29 14:58:06.902: //64/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
*Jun 29 14:58:06.903: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 29 Jun 2016 14:58:06 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.3.S2
Content-Length: 0
*Jun 29 14:58:06.903: //64/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:+358XXXXXXXX@10.7.13.12:5060 SIP/2.0
Via: SIP/2.0/UDP 10.13.13.250:5060;branch=z9hG4bK5B19F3
Remote-Party-ID: <sip:+491XXXXXXXX@10.13.13.250>;party=calling;screen=no;privacy=off
From: <sip:+491XXXXXXXX@10.13.13.250>;tag=CBEFFE-152B
To: <sip:+358XXXXXXXX@10.7.13.12>
Call-ID: B8CCCBEF-3D4011E6-80CB9970-DB779349@10.13.13.250
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 3100339425-1027609062-2160433520-3682046793
User-Agent: Cisco-SIPGateway/IOS-15.5.3.S2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1467212286
Contact: <sip:+491XXXXXXXX@10.13.13.250:5060>
Expires: 180
Max-Forwards: 68
Content-Length: 270
v=0
o=CiscoSystemsSIP-GW-UserAgent 1441 2001 IN IP4 10.13.13.250
s=SIP Call
c=IN IP4 10.13.13.250
t=0 0
m=audio 8122 RTP/AVP 0 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
*Jun 29 14:58:06.943: //64/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Wed, 29 Jun 2016 14:57:51 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
*Jun 29 14:58:07.038: //64/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:+358XXXXXXXX@10.7.13.12>;tag=66480~0f6c8596-6c7a-4e01-8f44-a9304615fc04-92134722
CSeq: 101 INVITE
Require: 100rel
RSeq: 1954516852
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Server: Cisco-CUCM11.0
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Session-ID: 0b8fb54900105000a00040a6e8b1786b;remote=80f67723258e5987682747b19ab66480
P-Asserted-Identity: <sip:+358XXXXXXXX@10.7.13.12>
Remote-Party-ID: <sip:+358XXXXXXXX@10.7.13.12>;party=called;screen=yes;privacy=off
Contact: <sip:+358XXXXXXXX@10.7.13.12:5060>;+u.sip!devicename.ccm.cisco.com="SEP40A6E8B1786B"
Content-Length: 0
*Jun 29 14:58:07.039: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
*Jun 29 14:58:07.039: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
*Jun 29 14:58:07.039: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Jun 29 14:58:07.039: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:7FA352F2CEB0
*Jun 29 14:58:07.039: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:07.039: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*Jun 29 14:58:07.039: //64/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
PRACK sip:+358XXXXXXXX@10.7.13.12:5060 SIP/2.0
Via: SIP/2.0/UDP 10.13.13.250:5060;branch=z9hG4bK5C470
CSeq: 102 PRACK
RAck: 1954516852 101 INVITE
Max-Forwards: 70
Content-Length: 0
*Jun 29 14:58:07.040: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:+358XXXXXXXX@193.64.250.10;user=phone>;tag=CBF087-1571
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Remote-Party-ID: <sip:+358XXXXXXXX@10.13.13.250>;party=called;screen=yes;privacy=off
Contact: <sip:+358XXXXXXXX@10.13.13.250:5060>
Content-Length: 0
*Jun 29 14:58:07.105: //64/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
*Jun 29 14:58:07.391: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 290
CSeq: 1 INVITE
Max-Forwards: 69
v=0
s=-
t=0 0
b=AS:80
a=fmtp:18 annexb=no
a=rtpmap:13 CN/8000
a=ptime:20
a=maxptime:20
*Jun 29 14:58:07.392: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:07.392: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 29 Jun 2016 14:58:07 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:07.539: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:07.540: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:08.391: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 290
CSeq: 1 INVITE
Max-Forwards: 69
v=0
s=-
t=0 0
b=AS:80
a=fmtp:18 annexb=no
a=rtpmap:13 CN/8000
a=ptime:20
a=maxptime:20
*Jun 29 14:58:08.392: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:08.393: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 29 Jun 2016 14:58:08 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:08.539: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:08.539: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:10.148: //64/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Require: timer
Content-Length: 220
v=0
o=CiscoSystemsCCM-SIP 66480 1 IN IP4 10.7.13.12
s=SIP Call
c=IN IP4 10.13.1.80
b=TIAS:64000
b=AS:64
t=0 0
m=audio 17116 RTP/AVP 0 101
a=fmtp:101 0-15
*Jun 29 14:58:10.149: //64/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Jun 29 14:58:10.149: //64/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:7FA352F2C4F0
*Jun 29 14:58:10.149: //64/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:uac, Min-SE Value:1800, flags:120
*Jun 29 14:58:10.150: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_IWF
*Jun 29 14:58:10.151: //64/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.13.13.250:5060;branch=z9hG4bK5D254A
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
*Jun 29 14:58:10.152: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_HA_CHKPNT_NOTIFY
*Jun 29 14:58:10.153: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
*Jun 29 14:58:10.153: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*Jun 29 14:58:10.391: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 290
CSeq: 1 INVITE
Max-Forwards: 69
v=0
s=-
t=0 0
b=AS:80
a=fmtp:18 annexb=no
a=rtpmap:13 CN/8000
a=ptime:20
a=maxptime:20
*Jun 29 14:58:10.392: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:10.392: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 29 Jun 2016 14:58:10 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:10.540: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:10.540: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:14.391: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 290
CSeq: 1 INVITE
Max-Forwards: 69
v=0
s=-
t=0 0
b=AS:80
a=fmtp:18 annexb=no
a=rtpmap:13 CN/8000
a=ptime:20
a=maxptime:20
*Jun 29 14:58:14.392: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:14.392: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 29 Jun 2016 14:58:14 GMT
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:14.540: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:14.540: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:18.540: //63/B8CB6CE180C5/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
*Jun 29 14:58:18.540: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Require: 100rel
RSeq: 5609
Content-Length: 0
*Jun 29 14:58:21.686: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:+491XXXXXXXX@10.13.13.250:5060 SIP/2.0
Via: SIP/2.0/UDP 10.7.13.12:5060;branch=z9hG4bK3cb177773887
From: <sip:+358XXXXXXXX@10.7.13.12>;tag=66480~0f6c8596-6c7a-4e01-8f44-a9304615fc04-92134722
To: <sip:+491XXXXXXXX@10.13.13.250>;tag=CBEFFE-152B
Date: Wed, 29 Jun 2016 14:57:54 GMT
User-Agent: Cisco-CUCM11.0
Max-Forwards: 70
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
*Jun 29 14:58:21.688: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Jun 29 14:58:21.688: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
*Jun 29 14:58:21.689: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Jun 29 14:58:21.689: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:500, container:7FA352F2C4F0
*Jun 29 14:58:21.689: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
CSeq: 1 INVITE
Content-Length: 0
*Jun 29 14:58:21.690: //64/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 29 Jun 2016 14:58:21 GMT
CSeq: 101 BYE
Content-Length: 0
*Jun 29 14:58:21.691: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_VOIPRTP_FPI_EVENT
*Jun 29 14:58:22.190: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*Jun 29 14:58:22.392: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 290
CSeq: 1 INVITE
Max-Forwards: 69
v=0
s=-
t=0 0
b=AS:80
a=fmtp:18 annexb=no
a=rtpmap:13 CN/8000
a=ptime:20
a=maxptime:20
*Jun 29 14:58:22.392: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
FI-HEL-CUBE01#
FI-HEL-CUBE01#
FI-HEL-CUBE01#
FI-HEL-CUBE01#
*Jun 29 14:58:22.392: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:500, container:7FA352F2BC68
*Jun 29 14:58:22.393: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 29 Jun 2016 14:58:22 GMT
CSeq: 1 INVITE
Content-Length: 0
*Jun 29 14:58:23.189: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*Jun 29 14:58:25.189: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*Jun 29 14:58:29.190: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*Jun 29 14:58:33.191: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*Jun 29 14:58:37.191: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 1 INVITE
Content-Length: 0
*Jun 29 14:58:38.392: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 290
CSeq: 1 INVITE
Max-Forwards: 69
v=0
s=-
t=0 0
b=AS:80
a=fmtp:18 annexb=no
a=rtpmap:13 CN/8000
a=ptime:20
a=maxptime:20
*Jun 29 14:58:38.393: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
*Jun 29 14:58:38.393: //63/B8CB6CE180C5/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:500, container:7FA352F2D7A0
*Jun 29 14:58:38.393: //63/B8CB6CE180C5/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 29 Jun 2016 14:58:38 GMT
CSeq: 1 INVITE
Content-Length: 0
Deepak Mehta
Hi Jamie,
Can you paste cube config.i can see after cube sends early offer invite to CUCM., it responds with  200 ok with contact ip of 10.13.1.80
Is it phone ip or something else ,this ip should be reachable from CUBE.I am assuming you don't have FW etc ?
CUBE-10.13.13.250
CUCM-10.7.13.12
SP-194.157.170.75
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Require: timer
Content-Length: 220
v=0
s=SIP Call
c=IN IP4 10.13.1.80 >>>>>>>>>>>>>>>>>>>>
b=TIAS:64000
b=AS:64
t=0 0
a=fmtp:101 0-15
