Inbound CLID name - CUCM
Rob McCarty
I have a large list of translation patterns for outbound speed dials.  Works fine for outbound, and of course we can mask the calling ID outbound
For inbound, Id like to have names attached to this same list, for example 18005555555 calls and I see "Bob's Plumbing".  Its about 400 numbers and of course the PSTN only sends in a number. Whats the best way to do this?  Translation seems to only be for numbering inbound
If I put them in a global directory would that accomplish it? If so, is there a way to bulk admin this from CUCM?
CUCM 10.5, MGCP gw, 7942 phones
Suresh Hudda
CUCM doesn't support number to name resolution.
Suresh
Jaime Valencia
You need a 3rd party to do that, Paolo has a script for that.
java
if this helps, please rate
try to follow this link: http://www.2ring.com/ipps
2Ring PHONE SERVICES can help you.
HTH,
Martin
