Inbound international calls on one particular phone/extension only
Shahbaz
Hi Team,
I have a customer which would like to receive Inbound international calls on one particular phone/extension only. Below is the detail. Can you please suggest?
1: Callmanager software version  is 11.5
2: IP Phone Model is 7811
3: Voice gateway integration with cucm is through H.323
4: PSTN Circuit is PRI.
uspka
Put an extension on the phone and on the H323 gateway have a voice translation rule that will translate all intl calls (on dial peer) to the extension.
Hi uspka,
Thanks for the quick response. Can you pls share the config example of voice translation rule which will translate all intl calls (on dial-peer) ot the extension?
can you give an example of what the international number is that will be caLLED AND THE ACTual extension on that phone?
cheers
Please remember to rate useful posts, by clicking on the stars below.
