Inbound ITSP call to SIPREC server shows called Number as anonymous
We have an issue with Inbound calls to CUBE that when sent over to (Enghouse QMS Recording) via SIPREC the To Header is changed to anonymous.
It appears to work fine for the calling number;
10861624: *Jun 6 10:01:54.896: //23710213/9C3F82018706/SIP/Info/verbose/32768/ccsip_ipip_media_forking_BuildMediaRecParticipant: MF: Populate rec parti header from this leg.
10861625: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/33792/ccsip_get_recording_participant_header: MF: X-Cisco header is RPID..
10861626: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/33792/ccsip_get_recording_participant_header: MF: Building SIP URL..
10861627: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/32768/ccsip_get_recording_participant_header: MF: Sipuser = anonymous.
10861628: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/33792/ccsip_get_recording_participant_header: MF: Host = 10.1.x.x
10861629: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/verbose/32768/ccsip_ipip_media_forking_BuildMediaRecStream: MF: Adding a Audio stream..
10861630: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/32768/ccsip_ipip_media_forking_BuildAudioRecStream: MF: direction type =3 3
10861631: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/32768/ccsip_ipip_media_forking_BuildAudioRecStream: MF: callid 23710213 set to nearend..
10861632: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/32768/ccsip_ipip_media_forking_BuildAudioRecStream: MF: This rcstream has 23710213 callid
10861633: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/verbose/32768/ccsip_ipip_media_forking_BuildAudioRecStream: MF: Setting data for audio stream..
10861634: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/32800/ccsip_ipip_media_forking_BuildAudioRecStream: MF: dtmf is rtp-nte
10861635: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/critical/32768/ccsip_ipip_media_forking_BuildMediaRecStream: Only audio forking enabled, not offering video..
10861636: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/info/32768/ccsip_ipip_media_forking_BuildMediaRecParticipant: MF: First Participant..
10861637: *Jun 6 10:01:54.900: //23710213/9C3F82018706/SIP/Info/verbose/32768/ccsip_ipip_media_forking_BuildMediaRecParticipant: MF: Populate rec parti header from peer leg.
10861638: *Jun 6 10:01:54.900: //23710212/9C3F82018706/SIP/Info/verbose/32768/ccsip_get_recording_participant_header: MF: This is incoming leg.
10861639: *Jun 6 10:01:54.900: //23710212/9C3F82018706/SIP/Info/info/33792/ccsip_get_recording_participant_header: MF: Taking the rec part from FROM header.
10861640: *Jun 6 10:01:54.900: //23710212/9C3F82018706/SIP/Info/info/33792/ccsip_get_recording_participant_header: MF: X-Cisco header is TO/FROM..
10861641: *Jun 6 10:01:54.900: //23710212/9C3F82018706/SIP/Info/info/33792/ccsip_get_recording_participant_header: MF: Building SIP URL..
10861642: *Jun 6 10:01:54.900: //23710212/9C3F82018706/SIP/Info/info/33792/ccsip_get_recording_participant_header: MF: Sipuser = 074xxxxxxxx
10861643: *Jun 6 10:01:54.900: //23710212/9C3F82018706/SIP/Info/info/33792/ccsip_get_recording_participant_header: MF: Host = 88.x.x.x
<participant participant_id="nnEGWAN/Ee6HGLQYrsR8+g==">
<nameID aor="sip:anonymous@10.x.x.x">
</nameID>
</participant>
This is applied to the outbound to the Recording server.
voice class sip-profiles 301
rule 10 request INVITE peer-header sip Contact copy "(.*)" u01
rule 20 request INVITE peer-header sip To copy "(.*)" u02
rule 30 request INVITE peer-header sip From copy "(.*)" u03
rule 40 request INVITE peer-header sip Diversion copy "(.*)" u04
rule 50 request INVITE sip-header Unsupported add "Unsupported: val"
rule 60 request INVITE sip-header Unsupported modify ".*" "Remote-Party-ID: \u01"
rule 70 request INVITE sip-header Unsupported add "Unsupported: val"
rule 80 request INVITE sip-header Unsupported modify ".*" "Diversion: \u04"
rule 100 request INVITE sip-header Unsupported add "Unsupported: val"
rule 110 request INVITE sip-header Unsupported modify ".*" "OriginatingTo: \u02"
rule 120 request INVITE sip-header Unsupported add "Unsupported: val"
rule 130 request INVITE sip-header Unsupported modify ".*" "OriginatingFrom: \u03"
This is assigned on the initial call coming in to populate the headers;
voice class sip-copylist 300
sip-header From
sip-header Diversion
sip-header To
sip-header Contact
0 Replies 0
