Phone details
Wanted to see if there's a web based tool that with the phones mac address show what version they're running.
M02@rt37
Hello erodriguez@iqteksolutions.com,
As I know, there is no specific web-based tool provided by Cisco that allows you to determine the software version of Cisco IP phones based on their MAC addresses.
The software version of a Cisco IP phone can typically be obtained through the administration interfaces of the call control system you are using, such as (CUCM) or CME. These interfaces provide information about the registered devices, including their software versions.
Best regards
M02@rt37
Best regards
Yes I know that this can be obtain on the CUCM, but I asked because a site just sent the MAC's. Thanks for your response.
