Incoming and outgoing translation
Janos.nagy
Hello I have a problem with incoming and outgoing translations.
We are using the CUCM 8.0.3.20000-2.
Okay here my problem:
First I want to translate every incoming number from 000XXXXXXX to +XXXXXXX.
That works fine I used the Calling Party Transformation.
Pattern 000.!
remove Predot
Prefix +
But If I dial a number starting with 000XXXXXX I want to to deactivate the translate for outgoing calls.
It looks like that the rule for Calling Party Transformation works for my outgoing calls, too.
But I do not want to use the rule for outgoing calls.
So please can one of you describe me, how I can make a translation rule only for incoming calls and not for outgoing calls
Gergely Szabo
Hi, does this Calling Name Transformation Pattern reside in the None partition?
If yes, that might be a problem. Everything in the None partition is visible to all Calling Search Spaces.
What is the type of the connection used towards the PSTN? And what signalling is used? Does the provider send the called numbering type (Subscriber, National, International?)
G.
Sent from Cisco Technical Support Android App
Janos.nagy
Hello Gergely,
I try both I added the "Calling Party Transformation Pattern" to none partiton and everyone.
I used a H323 Cisco 2921 Voicegateway to redirect the calls from our provider to the CUCM.
And yes our provider sent the numbering type.
Hi Janos,
alright, so what you might want to do is to adjust the Incoming Calling Party Settings section. If the provider sends the number type "International" and the number starts with three zeros, you can strip 3 digits and prefix the remainder with +. This way the desired transformation occurs (and is applied to the missed call list, too).
About that partition thing: I was actually kind of asking you trying not to include a pattern in the None partition. Try to create a CSS that contains a partition that contains the transformation, and try it out on the phone level.
G.
