Line Group to Voicemail
Brett Williston
I am newbie with Cisco. I have only been using the system for a little over a month.
Our vendor set up a line group that rings to 2 extensions but unfortunately after about 8 rings it just hangs up.
How do I configure this to go to one of the extensions voicemail?
We are using UCM 9.1 and Unity Connection 9.1
Thank you.
Brett
2 Accepted Solutions
Jaime Valencia
Set the hunt pilot CFNA to VM in CUCM, then configure the hunt pilot DN as an alternate DN for whoever you want to get the VM in CUC.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Rob Huffman
Hi Brett,
Lets say the Hunt Pilot that relates to your Line Group is
DN 6000 and the two Line group members are 6223 & 6224.
We want the calls that route via 6000 and are unanswered to go the voicemail
of the user @ 6224.
You set the Call Forward settings @ the Hunt Pilot level "6000" to point to the Unity Connection Pilot
number.
In Unity Connection you will need to find user @ 6224 and the Edit> Alternate Extension
and Add/new Alternate extension of 6000. This way calls the hit Unity Connection via the
Hunt setup @ 6000 will end up @ 6224's mailbox
PS: +5 to my friend Java for beating me to the punch here
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
Jaime Valencia
java
java
Thank you. That works
Rob Huffman
Hi Brett,
of the user @ 6224.
number.
Cheers!
Rob
- The Clash
Thank you. That works.
