Incoming call issue
Pawan Arora
I am facing issue with my incoming calls, some time i got the incoming calls and some times not. I think there is some issue with my dial-peer configuration. Can you please help me out in this issues. I have captured the debug voice ccapi inout from my gateway, here the calling number is 9899525346 and the called number is 47771146. I have also attached my dial-peer configuration.
cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=9899525346
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr  7 07:16:21.339: //-1/69305571821D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x49A28CC0, Call Info(
   Calling Number=9899525346,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=47771146(TON=Unknown, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr  7 07:16:21.339: //-1/69305571821D/CCAPI/ccCheckClipClir:
   In: Calling Number=9899525346(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=9899525346(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Apr  7 07:16:21.339: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:21.339: :cc_get_feature_vsa malloc success
Apr  7 07:16:21.339:  cc_get_feature_vsa count is 3
Apr  7 07:16:21.339: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215039768,feature_id:2714
Apr  7 07:16:21.339: //2714/69305571821D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=9899525346(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=47771146(TON=Unknown, NPI=ISDN))
Apr  7 07:16:21.339: //2714/69305571821D/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:21.339: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 47771146
Apr  7 07:16:21.343: //2714/69305571821D/CCAPI/ccCallSetContext:
   Context=0x4A081608
Apr  7 07:16:21.343: //2714/69305571821D/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2714 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:21.343: //2714/69305571821D/CCAPI/ccCallProceeding:
Apr  7 07:16:21.347: //2714/69305571821D/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3, Params=0x4A087D98, Progress Indication=NULL(0)
Apr  7 07:16:21.347: //2714/69305571821D/CCAPI/ccCheckClipClir:
   Destination Pattern=477711.., Called Number=47771146, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=69305571-7FB8-11E1-821D-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:21.347: //2714/69305571821D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:21.347: //2714/69305571821D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48DDE448, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=9899525346,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=47771146(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Apr  7 07:16:21.347: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:21.347: :cc_get_feature_vsa malloc success
Apr  7 07:16:21.351: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:21.351:  cc_get_feature_vsa count is 4
Apr  7 07:16:21.351: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215039544,feature_id:2715
Apr  7 07:16:21.351: //2715/69305571821D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Apr  7 07:16:21.351: //2715/69305571821D/CCAPI/ccCallSetContext:
   Context=0x4A087D48
Apr  7 07:16:21.351: //2714/69305571821D/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:24.351: //2715/69305571821D/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2715
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Apr  7 07:16:24.351: //2714/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Apr  7 07:16:24.351: //2715/69305571821D/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2715
Apr  7 07:16:24.351: //2715/69305571821D/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Apr  7 07:16:24.351: //2715/69305571821D/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Apr  7 07:16:24.355: //2715/69305571821D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2715,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Apr  7 07:16:24.355: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:24.355: :cc_free_feature_vsa freeing 486C0830
Apr  7 07:16:24.355:  vsacount in free is 3
Apr  7 07:16:24.355: //2714/69305571821D/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x4A090258, Progress Indication=NULL(0)
Apr  7 07:16:24.355: //2714/69305571821D/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=47771146, Digit Strip=TRUE
Apr  7 07:16:24.359: //2714/69305571821D/CCAPI/ccCallSetupRequest:
   Guid=69305571-7FB8-11E1-821D-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:24.359: //2714/69305571821D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:24.359: //2714/69305571821D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49A28CC0, Interface Type=6, Destination=, Mode=0x0,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=9, Call Count On=FALSE,
Apr  7 07:16:24.359: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:24.359: :cc_get_feature_vsa malloc success
Apr  7 07:16:24.359:  cc_get_feature_vsa count is 4
Apr  7 07:16:24.359: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215039544,feature_id:2716
Apr  7 07:16:24.359: //2716/69305571821D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Apr  7 07:16:24.359: //2716/69305571821D/CCAPI/ccCallSetContext:
   Context=0x4A090208
Apr  7 07:16:24.359: //2714/69305571821D/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:24.403: //2716/69305571821D/CCAPI/cc_api_call_proceeding:
   Interface=0x49A28CC0, Progress Indication=NULL(0)
Apr  7 07:16:24.507: //-1/6B1457D3821E/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=1147771100
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:24.511: //-1/6B1457D3821E/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=1147771100,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Apr  7 07:16:24.511: //-1/6B1457D3821E/CCAPI/ccCheckClipClir:
   In: Calling Number=1147771100(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=1147771100(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Apr  7 07:16:24.511: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:24.511: :cc_get_feature_vsa malloc success
Apr  7 07:16:24.511:  cc_get_feature_vsa count is 5
Apr  7 07:16:24.511: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215039320,feature_id:2717
Apr  7 07:16:24.511: //2717/6B1457D3821E/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1147771100(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Apr  7 07:16:24.511: //2717/6B1457D3821E/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:24.511: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:24.511: //2717/6B1457D3821E/CCAPI/ccCallSetContext:
   Context=0x4A080748
Apr  7 07:16:24.515: //2717/6B1457D3821E/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2717 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:24.515: //2717/6B1457D3821E/CCAPI/ccCallProceeding:
Apr  7 07:16:24.519: //2717/6B1457D3821E/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x49DAC15C, Progress Indication=NULL(0)
Apr  7 07:16:24.519: //2717/6B1457D3821E/CCAPI/ccCheckClipClir:
   Guid=6B1457D3-7FB8-11E1-821E-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:24.519: //2717/6B1457D3821E/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:24.519: //2717/6B1457D3821E/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=1147771100,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Apr  7 07:16:24.519: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:24.519: :cc_get_feature_vsa malloc success
Apr  7 07:16:24.519:  cc_get_feature_vsa count is 6
Apr  7 07:16:24.519: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215039096,feature_id:2718
Apr  7 07:16:24.523: //2718/6B1457D3821E/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:24.523: //2718/6B1457D3821E/CCAPI/ccCallSetContext:
   Context=0x49DAC10C
Apr  7 07:16:24.523: //2717/6B1457D3821E/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:27.523: //2718/6B1457D3821E/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2718
Apr  7 07:16:27.523: //2717/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:27.523: //2718/6B1457D3821E/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2718
Apr  7 07:16:27.523: //2718/6B1457D3821E/CCAPI/ccCallDisconnect:
Apr  7 07:16:27.523: //2718/6B1457D3821E/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:27.527: //2718/6B1457D3821E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2718,
Apr  7 07:16:27.527: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:27.527: :cc_free_feature_vsa freeing 486C0670
Apr  7 07:16:27.527:  vsacount in free is 5
Apr  7 07:16:27.527: //2717/6B1457D3821E/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x49DAED9C, Progress Indication=NULL(0)
Apr  7 07:16:27.527: //2717/6B1457D3821E/CCAPI/ccCheckClipClir:
Apr  7 07:16:27.531: //2717/6B1457D3821E/CCAPI/ccCallSetupRequest:
   Guid=6B1457D3-7FB8-11E1-821E-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:27.531: //2717/6B1457D3821E/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:27.531: //2717/6B1457D3821E/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:27.531: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:27.531: :cc_get_feature_vsa malloc success
Apr  7 07:16:27.531:  cc_get_feature_vsa count is 6
Apr  7 07:16:27.531: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215039096,feature_id:2719
Apr  7 07:16:27.531: //2719/6B1457D3821E/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:27.531: //2719/6B1457D3821E/CCAPI/ccCallSetContext:
   Context=0x49DAED4C
Apr  7 07:16:27.531: //2717/6B1457D3821E/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:27.579: //2719/6B1457D3821E/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:27.691: //-1/6CFA2E15821F/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:27.695: //-1/6CFA2E15821F/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=1147771100,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Apr  7 07:16:27.695: //-1/6CFA2E15821F/CCAPI/ccCheckClipClir:
   In: Calling Number=1147771100(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=1147771100(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Apr  7 07:16:27.695: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:27.695: :cc_get_feature_vsa malloc success
Apr  7 07:16:27.695:  cc_get_feature_vsa count is 7
Apr  7 07:16:27.695: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215038872,feature_id:2720
Apr  7 07:16:27.695: //2720/6CFA2E15821F/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1147771100(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Apr  7 07:16:27.699: //2720/6CFA2E15821F/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:27.699: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:27.699: //2720/6CFA2E15821F/CCAPI/ccCallSetContext:
   Context=0x4A08B848
   >>>>CCAPI handed cid 2720 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:27.699: //2720/6CFA2E15821F/CCAPI/ccCallProceeding:
Apr  7 07:16:27.703: //2720/6CFA2E15821F/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x49DAB29C, Progress Indication=NULL(0)
Apr  7 07:16:27.703: //2720/6CFA2E15821F/CCAPI/ccCheckClipClir:
   Guid=6CFA2E15-7FB8-11E1-821F-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:27.703: //2720/6CFA2E15821F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:27.707: //2720/6CFA2E15821F/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=1147771100,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Apr  7 07:16:27.707: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:27.707: :cc_get_feature_vsa malloc success
Apr  7 07:16:27.707:  cc_get_feature_vsa count is 8
Apr  7 07:16:27.707: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215038648,feature_id:2721
Apr  7 07:16:27.707: //2721/6CFA2E15821F/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:27.707: //2721/6CFA2E15821F/CCAPI/ccCallSetContext:
   Context=0x49DAB24C
Apr  7 07:16:27.707: //2720/6CFA2E15821F/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:30.711: //2721/6CFA2E15821F/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2721
Apr  7 07:16:30.711: //2720/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:30.711: //2721/6CFA2E15821F/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2721
Apr  7 07:16:30.711: //2721/6CFA2E15821F/CCAPI/ccCallDisconnect:
Apr  7 07:16:30.711: //2721/6CFA2E15821F/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:30.715: //2721/6CFA2E15821F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2721,
Apr  7 07:16:30.715: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:30.715: :cc_free_feature_vsa freeing 486C04B0
Apr  7 07:16:30.715:  vsacount in free is 7
Apr  7 07:16:30.715: //2720/6CFA2E15821F/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x49DBAD5C, Progress Indication=NULL(0)
Apr  7 07:16:30.715: //2720/6CFA2E15821F/CCAPI/ccCheckClipClir:
Apr  7 07:16:30.719: //2720/6CFA2E15821F/CCAPI/ccCallSetupRequest:
   Guid=6CFA2E15-7FB8-11E1-821F-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:30.719: //2720/6CFA2E15821F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:30.719: //2720/6CFA2E15821F/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:30.719: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:30.719: :cc_get_feature_vsa malloc success
Apr  7 07:16:30.719:  cc_get_feature_vsa count is 8
Apr  7 07:16:30.719: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215038648,feature_id:2722
Apr  7 07:16:30.719: //2722/6CFA2E15821F/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:30.719: //2722/6CFA2E15821F/CCAPI/ccCallSetContext:
   Context=0x49DBAD0C
Apr  7 07:16:30.719: //2720/6CFA2E15821F/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:30.763: //2722/6CFA2E15821F/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:30.883: //-1/6EE13D3F8220/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:30.887: //-1/6EE13D3F8220/CCAPI/cc_api_call_setup_ind_common:
Apr  7 07:16:30.887: //-1/6EE13D3F8220/CCAPI/ccCheckClipClir:
Apr  7 07:16:30.887: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:30.887: :cc_get_feature_vsa malloc success
Apr  7 07:16:30.887:  cc_get_feature_vsa count is 9
Apr  7 07:16:30.887: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215038424,feature_id:2723
Apr  7 07:16:30.887: //2723/6EE13D3F8220/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Apr  7 07:16:30.891: //2723/6EE13D3F8220/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:30.891: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:30.891: //2723/6EE13D3F8220/CCAPI/ccCallSetContext:
   Context=0x4A085FC8
   >>>>CCAPI handed cid 2723 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:30.891: //2723/6EE13D3F8220/CCAPI/ccCallProceeding:
Apr  7 07:16:30.895: //2723/6EE13D3F8220/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x49DAFC5C, Progress Indication=NULL(0)
Apr  7 07:16:30.895: //2723/6EE13D3F8220/CCAPI/ccCheckClipClir:
   Guid=6EE13D3F-7FB8-11E1-8220-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:30.895: //2723/6EE13D3F8220/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:30.899: //2723/6EE13D3F8220/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:30.899: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:30.899: :cc_get_feature_vsa malloc success
Apr  7 07:16:30.899:  cc_get_feature_vsa count is 10
Apr  7 07:16:30.899: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215038200,feature_id:2724
Apr  7 07:16:30.899: //2724/6EE13D3F8220/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:30.899: //2724/6EE13D3F8220/CCAPI/ccCallSetContext:
   Context=0x49DAFC0C
Apr  7 07:16:30.899: //2723/6EE13D3F8220/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:33.903: //2724/6EE13D3F8220/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2724
Apr  7 07:16:33.903: //2723/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:33.903: //2724/6EE13D3F8220/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2724
Apr  7 07:16:33.903: //2724/6EE13D3F8220/CCAPI/ccCallDisconnect:
Apr  7 07:16:33.903: //2724/6EE13D3F8220/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:33.907: //2724/6EE13D3F8220/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2724,
Apr  7 07:16:33.907: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:33.907: :cc_free_feature_vsa freeing 486C02F0
Apr  7 07:16:33.907:  vsacount in free is 9
Apr  7 07:16:33.907: //2723/6EE13D3F8220/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x4A08E4D8, Progress Indication=NULL(0)
Apr  7 07:16:33.907: //2723/6EE13D3F8220/CCAPI/ccCheckClipClir:
Apr  7 07:16:33.911: //2723/6EE13D3F8220/CCAPI/ccCallSetupRequest:
   Guid=6EE13D3F-7FB8-11E1-8220-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:33.911: //2723/6EE13D3F8220/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:33.911: //2723/6EE13D3F8220/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:33.911: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:33.911: :cc_get_feature_vsa malloc success
Apr  7 07:16:33.911:  cc_get_feature_vsa count is 10
Apr  7 07:16:33.911: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215038200,feature_id:2725
Apr  7 07:16:33.911: //2725/6EE13D3F8220/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:33.911: //2725/6EE13D3F8220/CCAPI/ccCallSetContext:
   Context=0x4A08E488
Apr  7 07:16:33.911: //2723/6EE13D3F8220/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:33.955: //2725/6EE13D3F8220/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:34.059: //-1/70C5DD368221/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:34.063: //-1/70C5DD368221/CCAPI/cc_api_call_setup_ind_common:
Apr  7 07:16:34.063: //-1/70C5DD368221/CCAPI/ccCheckClipClir:
Apr  7 07:16:34.063: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:34.063: :cc_get_feature_vsa malloc success
Apr  7 07:16:34.063:  cc_get_feature_vsa count is 11
Apr  7 07:16:34.063: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215037976,feature_id:2726
Apr  7 07:16:34.063: //2726/70C5DD368221/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Apr  7 07:16:34.063: //2726/70C5DD368221/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:34.063: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:34.067: //2726/70C5DD368221/CCAPI/ccCallSetContext:
   Context=0x49DBBBCC
Apr  7 07:16:34.067: //2726/70C5DD368221/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2726 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:34.067: //2726/70C5DD368221/CCAPI/ccCallProceeding:
Apr  7 07:16:34.071: //2726/70C5DD368221/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x4A089B18, Progress Indication=NULL(0)
Apr  7 07:16:34.071: //2726/70C5DD368221/CCAPI/ccCheckClipClir:
   Guid=70C5DD36-7FB8-11E1-8221-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:34.071: //2726/70C5DD368221/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:34.071: //2726/70C5DD368221/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:34.071: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:34.075: :cc_get_feature_vsa malloc success
Apr  7 07:16:34.075: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:34.075:  cc_get_feature_vsa count is 12
Apr  7 07:16:34.075: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215037752,feature_id:2727
Apr  7 07:16:34.075: //2727/70C5DD368221/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:34.075: //2727/70C5DD368221/CCAPI/ccCallSetContext:
   Context=0x4A089AC8
Apr  7 07:16:34.075: //2726/70C5DD368221/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:37.079: //2727/70C5DD368221/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2727
Apr  7 07:16:37.079: //2726/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:37.079: //2727/70C5DD368221/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2727
Apr  7 07:16:37.079: //2727/70C5DD368221/CCAPI/ccCallDisconnect:
Apr  7 07:16:37.079: //2727/70C5DD368221/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:37.083: //2727/70C5DD368221/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2727,
Apr  7 07:16:37.083: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:37.083: :cc_free_feature_vsa freeing 486C0130
Apr  7 07:16:37.083:  vsacount in free is 11
Apr  7 07:16:37.083: //2726/70C5DD368221/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x49DB811C, Progress Indication=NULL(0)
Apr  7 07:16:37.083: //2726/70C5DD368221/CCAPI/ccCheckClipClir:
   Guid=70C5DD36-7FB8-11E1-8221-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:37.087: //2726/70C5DD368221/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:37.087: //2726/70C5DD368221/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:37.087: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:37.087: :cc_get_feature_vsa malloc success
Apr  7 07:16:37.087:  cc_get_feature_vsa count is 12
Apr  7 07:16:37.087: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215037752,feature_id:2728
Apr  7 07:16:37.087: //2728/70C5DD368221/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:37.087: //2728/70C5DD368221/CCAPI/ccCallSetContext:
   Context=0x49DB80CC
Apr  7 07:16:37.087: //2726/70C5DD368221/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:37.167: //2728/70C5DD368221/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:37.239: //-1/72AB17E88222/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:37.243: //-1/72AB17E88222/CCAPI/cc_api_call_setup_ind_common:
Apr  7 07:16:37.243: //-1/72AB17E88222/CCAPI/ccCheckClipClir:
Apr  7 07:16:37.243: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:37.243: :cc_get_feature_vsa malloc success
Apr  7 07:16:37.243:  cc_get_feature_vsa count is 13
Apr  7 07:16:37.243: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215037528,feature_id:2729
Apr  7 07:16:37.243: //2729/72AB17E88222/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Apr  7 07:16:37.243: //2729/72AB17E88222/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:37.243: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:37.243: //2729/72AB17E88222/CCAPI/ccCallSetContext:
   Context=0x49DB9E4C
Apr  7 07:16:37.247: //2729/72AB17E88222/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2729 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:37.247: //2729/72AB17E88222/CCAPI/ccCallProceeding:
Apr  7 07:16:37.251: //2729/72AB17E88222/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x49DB289C, Progress Indication=NULL(0)
Apr  7 07:16:37.251: //2729/72AB17E88222/CCAPI/ccCheckClipClir:
   Guid=72AB17E8-7FB8-11E1-8222-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:37.251: //2729/72AB17E88222/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:37.251: //2729/72AB17E88222/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:37.251: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:37.251: :cc_get_feature_vsa malloc success
Apr  7 07:16:37.251:  cc_get_feature_vsa count is 14
Apr  7 07:16:37.251: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215037304,feature_id:2730
Apr  7 07:16:37.255: //2730/72AB17E88222/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:37.255: //2730/72AB17E88222/CCAPI/ccCallSetContext:
   Context=0x49DB284C
Apr  7 07:16:37.255: //2729/72AB17E88222/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:39.311: //2712/807FD3C74C04/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x48DDE448, Call Id=2712
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Apr  7 07:16:39.315: //2712/807FD3C74C04/CCAPI/ccConferenceDestroy:
   Conference Id=0x310, Tag=0x0
Apr  7 07:16:39.315: //2712/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x310, Source Interface=0x48DDE448, Source Call Id=2712,
   Destination Call Id=2713, Disposition=0x0, Tag=0x0
Apr  7 07:16:39.315: //2713/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x310, Source Interface=0x49A28CC0, Source Call Id=2713,
   Destination Call Id=2712, Disposition=0x0, Tag=0x0
Apr  7 07:16:39.315: //2712/807FD3C74C04/CCAPI/cc_generic_bridge_done:
Apr  7 07:16:39.319: //2712/807FD3C74C04/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Apr  7 07:16:39.319: //2712/807FD3C74C04/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:39.319: //2713/807FD3C74C04/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Apr  7 07:16:39.319: //2713/807FD3C74C04/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:39.543: //2712/807FD3C74C04/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:39.547: //2712/807FD3C74C04/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2712,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Apr  7 07:16:39.547: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:39.547: :cc_free_feature_vsa freeing 486C0AD0
Apr  7 07:16:39.547:  vsacount in free is 13
Apr  7 07:16:39.555: %ISDN-6-DISCONNECT: Interface Serial0/3/0:30  disconnected from 9910995257 , call lasted 29 seconds
Apr  7 07:16:40.423: //2713/807FD3C74C04/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2713,
Apr  7 07:16:40.427: //2713/807FD3C74C04/CCAPI/cc_api_call_disconnect_done:
Apr  7 07:16:40.427: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:40.427: :cc_free_feature_vsa freeing 486C09F0
Apr  7 07:16:40.427:  vsacount in free is 12
Apr  7 07:16:40.439: //2730/72AB17E88222/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2730
Apr  7 07:16:40.443: //2729/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:40.443: //2730/72AB17E88222/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2730
Apr  7 07:16:40.443: //2730/72AB17E88222/CCAPI/ccCallDisconnect:
Apr  7 07:16:40.443: //2730/72AB17E88222/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:40.443: //2730/72AB17E88222/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2730,
Apr  7 07:16:40.443: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:40.443: :cc_free_feature_vsa freeing 486BFF70
Apr  7 07:16:40.443:  vsacount in free is 11
Apr  7 07:16:40.447: //2729/72AB17E88222/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x49DB375C, Progress Indication=NULL(0)
Apr  7 07:16:40.447: //2729/72AB17E88222/CCAPI/ccCheckClipClir:
   Guid=72AB17E8-7FB8-11E1-8222-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:40.447: //2729/72AB17E88222/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:40.447: //2729/72AB17E88222/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:40.451: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:40.451: :cc_get_feature_vsa malloc success
Apr  7 07:16:40.451:  cc_get_feature_vsa count is 12
Apr  7 07:16:40.451: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215037304,feature_id:2731
Apr  7 07:16:40.451: //2731/72AB17E88222/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:40.451: //2731/72AB17E88222/CCAPI/ccCallSetContext:
   Context=0x49DB370C
Apr  7 07:16:40.451: //2729/72AB17E88222/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:40.935: //2731/72AB17E88222/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:40.947: //-1/74E045C88223/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:40.947: //-1/74E045C88223/CCAPI/cc_api_call_setup_ind_common:
Apr  7 07:16:40.947: //-1/74E045C88223/CCAPI/ccCheckClipClir:
Apr  7 07:16:40.947: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:40.947: :cc_get_feature_vsa malloc success
Apr  7 07:16:40.947:  cc_get_feature_vsa count is 13
Apr  7 07:16:40.951: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215039992,feature_id:2732
Apr  7 07:16:40.951: //2732/74E045C88223/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Apr  7 07:16:40.951: //2732/74E045C88223/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:40.951: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:40.951: //2732/74E045C88223/CCAPI/ccCallSetContext:
   Context=0x4A07F888
   >>>>CCAPI handed cid 2732 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:40.955: //2732/74E045C88223/CCAPI/ccCallProceeding:
Apr  7 07:16:40.955: //2732/74E045C88223/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x4A085158, Progress Indication=NULL(0)
Apr  7 07:16:40.955: //2732/74E045C88223/CCAPI/ccCheckClipClir:
Apr  7 07:16:40.959: //2732/74E045C88223/CCAPI/ccCheckClipClir:
Apr  7 07:16:40.959: //2732/74E045C88223/CCAPI/ccCallSetupRequest:
   Guid=74E045C8-7FB8-11E1-8223-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:40.959: //2732/74E045C88223/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:40.959: //2732/74E045C88223/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:40.959: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:40.959: :cc_get_feature_vsa malloc success
Apr  7 07:16:40.959:  cc_get_feature_vsa count is 14
Apr  7 07:16:40.959: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215040216,feature_id:2733
Apr  7 07:16:40.959: //2733/74E045C88223/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:40.959: //2733/74E045C88223/CCAPI/ccCallSetContext:
   Context=0x4A085108
Apr  7 07:16:40.959: //2732/74E045C88223/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:43.183: //-1/805D0DE24D04/CCAPI/cc_api_display_ie_subfields:
   cisco-username=RANJEET JHA
   cisco-ani=01147771135
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=9990689138
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:43.183: //-1/805D0DE24D04/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x48DDE448, Call Info(
   Calling Number=01147771135,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9990689138(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2734
Apr  7 07:16:43.183: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:43.183: :cc_get_feature_vsa malloc success
Apr  7 07:16:43.183:  cc_get_feature_vsa count is 15
Apr  7 07:16:43.183: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215037080,feature_id:2734
Apr  7 07:16:43.187: //2734/805D0DE24D04/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=01147771135(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9990689138(TON=Unknown, NPI=Unknown))
Apr  7 07:16:43.187: //2734/805D0DE24D04/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:43.187: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9990689138
Apr  7 07:16:43.187: //2734/805D0DE24D04/CCAPI/ccCallSetContext:
   Context=0x4A086E88
   >>>>CCAPI handed cid 2734 with tag 0 to app "_ManagedAppProcess_Default"
Apr  7 07:16:43.187: //2734/805D0DE24D04/CCAPI/ccCallProceeding:
Apr  7 07:16:43.191: //2734/805D0DE24D04/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x4A08A9D8, Progress Indication=NULL(0)
Apr  7 07:16:43.191: //2734/805D0DE24D04/CCAPI/ccCheckClipClir:
   In: Calling Number=01147771135(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=01147771135(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Destination Pattern=.T, Called Number=9990689138, Digit Strip=TRUE
   Account Number=RANJEET JHA, Final Destination Flag=TRUE,
   Guid=805D0DE2-F0E6-F1F7-4D04-5901C0A80908, Outgoing Dial-peer=9
Apr  7 07:16:43.191: //2734/805D0DE24D04/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=9990689138
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:43.195: //2734/805D0DE24D04/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=01147771135,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=9990689138(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=9, Call Count On=FALSE,
Apr  7 07:16:43.195: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:43.195: :cc_get_feature_vsa malloc success
Apr  7 07:16:43.195:  cc_get_feature_vsa count is 16
Apr  7 07:16:43.195: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215036856,feature_id:2735
Apr  7 07:16:43.195: //2735/805D0DE24D04/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:43.195: //2735/805D0DE24D04/CCAPI/ccCallSetContext:
   Context=0x4A08A988
Apr  7 07:16:43.195: //2734/805D0DE24D04/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:43.523: //2735/805D0DE24D04/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:44.203: //2733/74E045C88223/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2733
Apr  7 07:16:44.203: //2732/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:44.203: //2733/74E045C88223/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2733
Apr  7 07:16:44.203: //2733/74E045C88223/CCAPI/ccCallDisconnect:
Apr  7 07:16:44.203: //2733/74E045C88223/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:44.207: //2733/74E045C88223/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2733,
Apr  7 07:16:44.207: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:44.207: :cc_free_feature_vsa freeing 486C0AD0
Apr  7 07:16:44.207:  vsacount in free is 15
Apr  7 07:16:44.211: //2732/74E045C88223/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x49DB0B1C, Progress Indication=NULL(0)
Apr  7 07:16:44.211: //2732/74E045C88223/CCAPI/ccCheckClipClir:
   Guid=74E045C8-7FB8-11E1-8223-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:44.211: //2732/74E045C88223/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:44.211: //2732/74E045C88223/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:44.211: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:44.211: :cc_get_feature_vsa malloc success
Apr  7 07:16:44.211:  cc_get_feature_vsa count is 16
Apr  7 07:16:44.211: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215040216,feature_id:2736
Apr  7 07:16:44.211: //2736/74E045C88223/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:44.215: //2736/74E045C88223/CCAPI/ccCallSetContext:
   Context=0x49DB0ACC
Apr  7 07:16:44.215: //2732/74E045C88223/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:45.003: //2736/74E045C88223/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:45.031: //-1/774F72DE8224/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:45.031: //-1/774F72DE8224/CCAPI/cc_api_call_setup_ind_common:
Apr  7 07:16:45.031: //-1/774F72DE8224/CCAPI/ccCheckClipClir:
Apr  7 07:16:45.031: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:45.031: :cc_get_feature_vsa malloc success
Apr  7 07:16:45.031:  cc_get_feature_vsa count is 17
Apr  7 07:16:45.031: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215036632,feature_id:2737
Apr  7 07:16:45.031: //2737/774F72DE8224/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Apr  7 07:16:45.035: //2737/774F72DE8224/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:45.035: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:45.035: //2737/774F72DE8224/CCAPI/ccCallSetContext:
   Context=0x49DB720C
   >>>>CCAPI handed cid 2737 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:45.035: //2737/774F72DE8224/CCAPI/ccCallProceeding:
Apr  7 07:16:45.039: //2737/774F72DE8224/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x49DB19DC, Progress Indication=NULL(0)
Apr  7 07:16:45.039: //2737/774F72DE8224/CCAPI/ccCheckClipClir:
   Guid=774F72DE-7FB8-11E1-8224-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:45.039: //2737/774F72DE8224/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:45.043: //2737/774F72DE8224/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:45.043: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:45.043: :cc_get_feature_vsa malloc success
Apr  7 07:16:45.043:  cc_get_feature_vsa count is 18
Apr  7 07:16:45.043: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215036408,feature_id:2738
Apr  7 07:16:45.043: //2738/774F72DE8224/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:45.043: //2738/774F72DE8224/CCAPI/ccCallSetContext:
   Context=0x49DB198C
Apr  7 07:16:45.043: //2737/774F72DE8224/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:45.799: //-1/77ACD3DC8225/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=9560886083
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771135
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:45.799: //-1/77ACD3DC8225/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=9560886083,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=47771135(TON=Unknown, NPI=ISDN),
Apr  7 07:16:45.803: //-1/77ACD3DC8225/CCAPI/ccCheckClipClir:
   In: Calling Number=9560886083(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=9560886083(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Apr  7 07:16:45.803: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:45.803: :cc_get_feature_vsa malloc success
Apr  7 07:16:45.803:  cc_get_feature_vsa count is 19
Apr  7 07:16:45.803: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215036184,feature_id:2739
Apr  7 07:16:45.803: //2739/77ACD3DC8225/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=9560886083(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=47771135(TON=Unknown, NPI=ISDN))
Apr  7 07:16:45.803: //2739/77ACD3DC8225/CCAPI/cc_process_call_setup_ind:
   Event=0x49116BB0
Apr  7 07:16:45.803: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 47771135
Apr  7 07:16:45.803: //2739/77ACD3DC8225/CCAPI/ccCallSetContext:
   Context=0x4A07E9C8
Apr  7 07:16:45.807: //2739/77ACD3DC8225/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2739 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:45.807: //2739/77ACD3DC8225/CCAPI/ccCallProceeding:
Apr  7 07:16:45.811: //2739/77ACD3DC8225/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x4A082518, Progress Indication=NULL(0)
Apr  7 07:16:45.811: //2739/77ACD3DC8225/CCAPI/ccCheckClipClir:
   Destination Pattern=477711.., Called Number=47771135, Digit Strip=FALSE
   Guid=77ACD3DC-7FB8-11E1-8225-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:45.811: //2739/77ACD3DC8225/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771135
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:45.811: //2739/77ACD3DC8225/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=9560886083,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=47771135(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
Apr  7 07:16:45.811: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:45.811: :cc_get_feature_vsa malloc success
Apr  7 07:16:45.811:  cc_get_feature_vsa count is 20
Apr  7 07:16:45.811: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215035960,feature_id:2740
Apr  7 07:16:45.815: //2740/77ACD3DC8225/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:45.815: //2740/77ACD3DC8225/CCAPI/ccCallSetContext:
   Context=0x4A0824C8
Apr  7 07:16:45.815: //2739/77ACD3DC8225/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:46.755: //2735/805D0DE24D04/CCAPI/cc_api_call_alert:
   Interface=0x49A28CC0, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255)
   Call Entry(Retry Count=0, Responsed=TRUE)
Apr  7 07:16:46.755: //2734/805D0DE24D04/CCAPI/ccCallAlert:
   Progress Indication=INBAND(8), Signal Indication=NOT PRESENT(255)
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Apr  7 07:16:46.755: //2735/805D0DE24D04/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
Apr  7 07:16:46.755: //2734/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x486C7CBC, callID1=0xAAE, callID2=0xAAF, tag=0x0)
   (confID=0x486C7CBC, callID1=0xAAE, gcid=0-0-0-0, tag=0x0)
Apr  7 07:16:46.755: //2735/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x486C7CBC, callID2=0xAAF, gcid=0-0-0-0, tag=0x0)
Apr  7 07:16:46.759: //2734/805D0DE24D04/CCAPI/ccConferenceCreate:
   Conference Id=0x486C7CBC, Call Id1=2734, Call Id2=2735, Tag=0x0
Apr  7 07:16:46.759: //2734/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Apr  7 07:16:46.759: cc_api_get_xcode_stream : 4452
Apr  7 07:16:46.759: //2734/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x311, Source Interface=0x48DDE448, Source Call Id=2734,
   Destination Call Id=2735, Disposition=0x0, Tag=0x0
Apr  7 07:16:46.759: //2735/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x311, Source Interface=0x49A28CC0, Source Call Id=2735,
   Destination Call Id=2734, Disposition=0x0, Tag=0xFFFFFFFF
Apr  7 07:16:46.759: //2734/805D0DE24D04/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x311, Destination Call Id=2735)
Apr  7 07:16:46.759: //2735/805D0DE24D04/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x311, Destination Call Id=2734)
Apr  7 07:16:46.759: //2735/805D0DE24D04/CCAPI/cc_api_caps_ind:
   Destination Interface=0x48DDE448, Destination Call Id=2734, Source Call Id=2735,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Apr  7 07:16:46.759: //2734/805D0DE24D04/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
Apr  7 07:16:46.763: //2734/805D0DE24D04/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x311, Call Id1=2734, Call Id2=2735
Apr  7 07:16:47.659: //2734/805D0DE24D04/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49A28CC0, Destination Call Id=2735, Source Call Id=2734,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
Apr  7 07:16:47.659: //2734/805D0DE24D04/CCAPI/cc_api_caps_ack:
   Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=20, Signal Type=2, Seq Num Start=8342)
   Caps(Codec=0x10000000, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
   Caps(Codec=g722-64(0x10000000), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8342)
Apr  7 07:16:47.663: //2735/805D0DE24D04/CCAPI/cc_api_caps_ack:
Apr  7 07:16:47.679: //2735/805D0DE24D04/CCAPI/cc_api_voice_mode_event:
   Call Id=2735
   Call Entry(Context=0x4A08A988)
Apr  7 07:16:47.683: //2735/805D0DE24D04/CCAPI/cc_api_voice_mode_event:
   Call Id=2735
Apr  7 07:16:47.687: //2734/805D0DE24D04/CCAPI/cc_api_caps_ind:
Apr  7 07:16:47.687: //2734/805D0DE24D04/CCAPI/cc_api_caps_ack:
Apr  7 07:16:47.691: //2735/805D0DE24D04/CCAPI/cc_api_caps_ack:
Apr  7 07:16:47.691: //2735/805D0DE24D04/CCAPI/cc_api_voice_mode_event:
   Call Id=2735
Apr  7 07:16:48.571: //2738/774F72DE8224/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2738
Apr  7 07:16:48.575: //2737/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:48.575: //2738/774F72DE8224/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2738
Apr  7 07:16:48.575: //2738/774F72DE8224/CCAPI/ccCallDisconnect:
Apr  7 07:16:48.575: //2738/774F72DE8224/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:48.579: //2738/774F72DE8224/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2738,
Apr  7 07:16:48.579: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:48.579: :cc_free_feature_vsa freeing 486BFBF0
Apr  7 07:16:48.579:  vsacount in free is 19
Apr  7 07:16:48.579: //2737/774F72DE8224/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x49DB461C, Progress Indication=NULL(0)
Apr  7 07:16:48.583: //2737/774F72DE8224/CCAPI/ccCheckClipClir:
Apr  7 07:16:48.583: //2737/774F72DE8224/CCAPI/ccCallSetupRequest:
   Guid=774F72DE-7FB8-11E1-8224-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:48.583: //2737/774F72DE8224/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:48.583: //2737/774F72DE8224/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:48.583: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:48.583: :cc_get_feature_vsa malloc success
Apr  7 07:16:48.583:  cc_get_feature_vsa count is 20
Apr  7 07:16:48.583: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215036408,feature_id:2741
Apr  7 07:16:48.583: //2741/774F72DE8224/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:48.583: //2741/774F72DE8224/CCAPI/ccCallSetContext:
   Context=0x49DB45CC
Apr  7 07:16:48.583: //2737/774F72DE8224/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:49.175: //2741/774F72DE8224/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:49.203: //2740/77ACD3DC8225/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2740
Apr  7 07:16:49.207: //2739/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:49.207: //2740/77ACD3DC8225/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2740
Apr  7 07:16:49.207: //2740/77ACD3DC8225/CCAPI/ccCallDisconnect:
Apr  7 07:16:49.207: //2740/77ACD3DC8225/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:49.215: //2740/77ACD3DC8225/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2740,
Apr  7 07:16:49.215: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:49.215: :cc_free_feature_vsa freeing 486BFA30
Apr  7 07:16:49.215:  vsacount in free is 19
Apr  7 07:16:49.219: //-1/79CDE0388226/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:49.219: //-1/79CDE0388226/CCAPI/cc_api_call_setup_ind_common:
Apr  7 07:16:49.219: //-1/79CDE0388226/CCAPI/ccCheckClipClir:
Apr  7 07:16:49.219: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:49.219: :cc_get_feature_vsa malloc success
Apr  7 07:16:49.219:  cc_get_feature_vsa count is 20
Apr  7 07:16:49.219: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215035960,feature_id:2742
Apr  7 07:16:49.219: //2742/79CDE0388226/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Apr  7 07:16:49.223: //2739/77ACD3DC8225/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x49DB639C, Progress Indication=NULL(0)
Apr  7 07:16:49.223: //2739/77ACD3DC8225/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=47771135, Digit Strip=TRUE
   Guid=77ACD3DC-7FB8-11E1-8225-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:49.223: //2739/77ACD3DC8225/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771135
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:49.227: //2739/77ACD3DC8225/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:49.227: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:49.227: :cc_get_feature_vsa malloc success
Apr  7 07:16:49.227:  cc_get_feature_vsa count is 21
Apr  7 07:16:49.227: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215035736,feature_id:2743
Apr  7 07:16:49.227: //2743/77ACD3DC8225/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:49.227: //2743/77ACD3DC8225/CCAPI/ccCallSetContext:
   Context=0x49DB634C
Apr  7 07:16:49.227: //2739/77ACD3DC8225/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:49.231: //2742/79CDE0388226/CCAPI/cc_process_call_setup_ind:
   Event=0x49116218
Apr  7 07:16:49.231: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:49.231: //2742/79CDE0388226/CCAPI/ccCallSetContext:
   Context=0x49DB8F8C
   >>>>CCAPI handed cid 2742 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:49.235: //2742/79CDE0388226/CCAPI/ccCallProceeding:
Apr  7 07:16:49.239: //2742/79CDE0388226/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x49DAD01C, Progress Indication=NULL(0)
Apr  7 07:16:49.239: //2742/79CDE0388226/CCAPI/ccCheckClipClir:
   Guid=79CDE038-7FB8-11E1-8226-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:49.243: //2742/79CDE0388226/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:49.243: //2742/79CDE0388226/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:49.243: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:49.243: :cc_get_feature_vsa malloc success
Apr  7 07:16:49.243:  cc_get_feature_vsa count is 22
Apr  7 07:16:49.243: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215035512,feature_id:2744
Apr  7 07:16:49.243: //2744/79CDE0388226/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:49.243: //2744/79CDE0388226/CCAPI/ccCallSetContext:
   Context=0x49DACFCC
Apr  7 07:16:49.243: //2742/79CDE0388226/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:49.583: //2743/77ACD3DC8225/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:49.595: //-1/7A07DACC8227/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771135
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:49.595: //-1/7A07DACC8227/CCAPI/cc_api_call_setup_ind_common:
Apr  7 07:16:49.595: //-1/7A07DACC8227/CCAPI/ccCheckClipClir:
Apr  7 07:16:49.595: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:49.595: :cc_get_feature_vsa malloc success
Apr  7 07:16:49.595:  cc_get_feature_vsa count is 23
Apr  7 07:16:49.595: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215035288,feature_id:2745
Apr  7 07:16:49.595: //2745/7A07DACC8227/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
Apr  7 07:16:49.599: //2745/7A07DACC8227/CCAPI/cc_process_call_setup_ind:
   Event=0x49116218
Apr  7 07:16:49.599: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:49.599: //2745/7A07DACC8227/CCAPI/ccCallSetContext:
   Context=0x49DADE8C
   >>>>CCAPI handed cid 2745 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:49.599: //2745/7A07DACC8227/CCAPI/ccCallProceeding:
Apr  7 07:16:49.603: //2745/7A07DACC8227/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x4A0833D8, Progress Indication=NULL(0)
Apr  7 07:16:49.603: //2745/7A07DACC8227/CCAPI/ccCheckClipClir:
   Guid=7A07DACC-7FB8-11E1-8227-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:49.603: //2745/7A07DACC8227/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771135
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:49.607: //2745/7A07DACC8227/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:49.607: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:49.607: :cc_get_feature_vsa malloc success
Apr  7 07:16:49.607:  cc_get_feature_vsa count is 24
Apr  7 07:16:49.607: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215035064,feature_id:2746
Apr  7 07:16:49.607: //2746/7A07DACC8227/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:49.607: //2746/7A07DACC8227/CCAPI/ccCallSetContext:
   Context=0x4A083388
Apr  7 07:16:49.607: //2745/7A07DACC8227/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:50.823: %ISDN-6-CONNECT: Interface Serial0/3/0:22 is now connected to 9990689138 N/A
Apr  7 07:16:50.823: //2735/805D0DE24D04/CCAPI/cc_api_call_connected:
   Interface=0x49A28CC0, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Apr  7 07:16:50.867: //2734/805D0DE24D04/CCAPI/ccCallConnect:
   Progress Indication=INBAND(8), Data Bitmask=0x1
Apr  7 07:16:50.867: //2735/805D0DE24D04/CCAPI/cc_api_get_called_ccm_detected:
   Call Entry(Connected=TRUE, Responsed=TRUE)
Apr  7 07:16:50.871: %ISDN-6-CONNECT: Interface Serial0/3/0:22 is now connected to 9990689138 N/A
Apr  7 07:16:51.407: %ISDN-6-CONNECT: Interface Serial0/3/0:22 is now connected to 9990689138 N/A
Apr  7 07:16:51.407: //2714/69305571821D/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2714
   Call Entry(Responsed=FALSE, Cause Value=102, Retry Count=0)
Apr  7 07:16:51.411: //2716/69305571821D/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=102, Call Entry(Responsed=FALSE, Cause Value=102)
Apr  7 07:16:51.411: //2716/69305571821D/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:51.419: //2714/69305571821D/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Apr  7 07:16:51.419: //2714/69305571821D/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:51.427: //2714/69305571821D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2714,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
Apr  7 07:16:51.427: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:51.427: :cc_free_feature_vsa freeing 486C0910
Apr  7 07:16:51.427:  vsacount in free is 23
Apr  7 07:16:52.251: //2717/6B1457D3821E/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2717
Apr  7 07:16:52.255: //2719/6B1457D3821E/CCAPI/ccCallDisconnect:
Apr  7 07:16:52.255: //2719/6B1457D3821E/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:52.287: //2744/79CDE0388226/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2744
Apr  7 07:16:52.295: //2717/6B1457D3821E/CCAPI/ccCallDisconnect:
Apr  7 07:16:52.295: //2717/6B1457D3821E/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:52.303: //2742/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
Apr  7 07:16:52.303: //2744/79CDE0388226/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2744
Apr  7 07:16:52.303: //2744/79CDE0388226/CCAPI/ccCallDisconnect:
Apr  7 07:16:52.307: //2744/79CDE0388226/CCAPI/ccCallDisconnect:
Apr  7 07:16:52.307: //2744/79CDE0388226/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:52.307: //2716/69305571821D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2716,
Apr  7 07:16:52.307: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:52.307: :cc_free_feature_vsa freeing 486C0830
Apr  7 07:16:52.307:  vsacount in free is 22
Apr  7 07:16:52.307: //2717/6B1457D3821E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2717,
Apr  7 07:16:52.311: //2717/6B1457D3821E/CCAPI/cc_api_call_disconnect_done:
Apr  7 07:16:52.311: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:52.311: :cc_free_feature_vsa freeing 486C0750
Apr  7 07:16:52.311:  vsacount in free is 21
Apr  7 07:16:52.311: //2744/79CDE0388226/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2744,
Apr  7 07:16:52.311: :cc_free_feature_vsa freeing 486BF870
Apr  7 07:16:52.311:  vsacount in free is 20
Apr  7 07:16:52.315: //2742/79CDE0388226/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x4A084298, Progress Indication=NULL(0)
Apr  7 07:16:52.315: //2742/79CDE0388226/CCAPI/ccCheckClipClir:
Apr  7 07:16:52.319: //2742/79CDE0388226/CCAPI/ccCheckClipClir:
Apr  7 07:16:52.319: //2742/79CDE0388226/CCAPI/ccCallSetupRequest:
   Guid=79CDE038-7FB8-11E1-8226-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:52.319: //2742/79CDE0388226/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr  7 07:16:52.319: //2742/79CDE0388226/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:52.319: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:52.319: :cc_get_feature_vsa malloc success
Apr  7 07:16:52.319:  cc_get_feature_vsa count is 21
Apr  7 07:16:52.319: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215035512,feature_id:2747
Apr  7 07:16:52.319: //2747/79CDE0388226/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:52.319: //2747/79CDE0388226/CCAPI/ccCallSetContext:
   Context=0x4A084248
Apr  7 07:16:52.319: //2742/79CDE0388226/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:52.463: //2720/6CFA2E15821F/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2720
Apr  7 07:16:52.467: //2722/6CFA2E15821F/CCAPI/ccCallDisconnect:
Apr  7 07:16:52.467: //2722/6CFA2E15821F/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:52.475: //2720/6CFA2E15821F/CCAPI/ccCallDisconnect:
Apr  7 07:16:52.475: //2720/6CFA2E15821F/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:52.479: //2747/79CDE0388226/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:52.495: //-1/7BC1C0738228/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:52.495: //-1/7BC1C0738228/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x49A28CC0, Call Info(
   Called Number=47771146(TON=Unknown, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr  7 07:16:52.495: //-1/7BC1C0738228/CCAPI/ccCheckClipClir:
Apr  7 07:16:52.495: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:52.495: :cc_get_feature_vsa malloc success
Apr  7 07:16:52.495:  cc_get_feature_vsa count is 22
Apr  7 07:16:52.495: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215039320,feature_id:2748
Apr  7 07:16:52.495: //2748/7BC1C0738228/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=47771146(TON=Unknown, NPI=ISDN))
Apr  7 07:16:52.499: //2719/6B1457D3821E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2719,
Apr  7 07:16:52.499: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:52.499: :cc_free_feature_vsa freeing 486C0670
Apr  7 07:16:52.499:  vsacount in free is 21
Apr  7 07:16:52.499: //2720/6CFA2E15821F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2720,
Apr  7 07:16:52.499: :cc_free_feature_vsa freeing 486C0590
Apr  7 07:16:52.499:  vsacount in free is 20
Apr  7 07:16:52.503: //2748/7BC1C0738228/CCAPI/cc_process_call_setup_ind:
   Event=0x49117EE0
Apr  7 07:16:52.503: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 47771146
Apr  7 07:16:52.503: //2748/7BC1C0738228/CCAPI/ccCallSetContext:
   Context=0x4A08C708
   >>>>CCAPI handed cid 2748 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:52.507: //2748/7BC1C0738228/CCAPI/ccCallProceeding:
Apr  7 07:16:52.507: //2748/7BC1C0738228/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3, Params=0x4A08D618, Progress Indication=NULL(0)
Apr  7 07:16:52.511: //2748/7BC1C0738228/CCAPI/ccCheckClipClir:
Apr  7 07:16:52.511: //2748/7BC1C0738228/CCAPI/ccCallSetupRequest:
   Destination Pattern=477711.., Called Number=47771146, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=7BC1C073-7FB8-11E1-8228-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:52.511: //2748/7BC1C0738228/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771146
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:52.511: //2748/7BC1C0738228/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48DDE448, Interface Type=1, Destination=, Mode=0x0,
   Called Number=47771146(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Apr  7 07:16:52.511: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:52.511: :cc_get_feature_vsa malloc success
Apr  7 07:16:52.511:  cc_get_feature_vsa count is 21
Apr  7 07:16:52.511: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215038872,feature_id:2749
Apr  7 07:16:52.511: //2749/7BC1C0738228/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Apr  7 07:16:52.511: //2749/7BC1C0738228/CCAPI/ccCallSetContext:
   Context=0x4A08D5C8
Apr  7 07:16:52.511: //2748/7BC1C0738228/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:52.523: //2723/6EE13D3F8220/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2723
Apr  7 07:16:52.523: //2725/6EE13D3F8220/CCAPI/ccCallDisconnect:
Apr  7 07:16:52.523: //2725/6EE13D3F8220/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Apr  7 07:16:52.531: //2723/6EE13D3F8220/CCAPI/ccCallDisconnect:
Apr  7 07:16:52.535: //2723/6EE13D3F8220/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:52.543: //2722/6CFA2E15821F/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2722,
   Call Disconnect Event Sent
Apr  7 07:16:52.543: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:52.543: :cc_free_feature_vsa freeing 486C04B0
Apr  7 07:16:52.543:  vsacount in free is 20
Apr  7 07:16:52.551: //2723/6EE13D3F8220/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2723,
Apr  7 07:16:52.551: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:52.551: :cc_free_feature_vsa freeing 486C03D0
Apr  7 07:16:52.551:  vsacount in free is 19
Apr  7 07:16:53.363: //2726/70C5DD368221/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2726
Apr  7 07:16:53.367: //2728/70C5DD368221/CCAPI/ccCallDisconnect:
Apr  7 07:16:53.367: //2728/70C5DD368221/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:53.367: //2746/7A07DACC8227/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2746
Apr  7 07:16:53.371: //2746/7A07DACC8227/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=38, Retry Count=0)
Apr  7 07:16:53.415: //2726/70C5DD368221/CCAPI/ccCallDisconnect:
Apr  7 07:16:53.419: //2726/70C5DD368221/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:53.423: //2745/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Apr  7 07:16:53.427: //2746/7A07DACC8227/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=2746
Apr  7 07:16:53.427: //2746/7A07DACC8227/CCAPI/ccCallDisconnect:
   Cause Value=38, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=38)
   Cause Value=38, Call Entry(Responsed=TRUE, Cause Value=38)
Apr  7 07:16:53.427: //2746/7A07DACC8227/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:53.427: //2746/7A07DACC8227/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48DDE448, Tag=0x0, Call Id=2746,
   Call Entry(Disconnect Cause=38, Voice Class Cause Code=0, Retry Count=0)
Apr  7 07:16:53.431: //2746/7A07DACC8227/CCAPI/cc_api_call_disconnect_done:
Apr  7 07:16:53.431: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:53.431: :cc_free_feature_vsa freeing 486BF6B0
Apr  7 07:16:53.431:  vsacount in free is 18
Apr  7 07:16:53.431: //2745/7A07DACC8227/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x49DB54DC, Progress Indication=NULL(0)
Apr  7 07:16:53.431: //2745/7A07DACC8227/CCAPI/ccCheckClipClir:
   In: Calling Number=1147771100(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=1147771100(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Calling Number=1147771100(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Guid=7A07DACC-7FB8-11E1-8227-001E7A5E63D8, Outgoing Dial-peer=9
Apr  7 07:16:53.431: //2745/7A07DACC8227/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=1147771100
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=47771135
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:53.435: //2745/7A07DACC8227/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49A28CC0, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=1147771100,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=9, Call Count On=FALSE,
Apr  7 07:16:53.435: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:53.435: :cc_get_feature_vsa malloc success
Apr  7 07:16:53.435:  cc_get_feature_vsa count is 19
Apr  7 07:16:53.435: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215035064,feature_id:2750
Apr  7 07:16:53.435: //2750/7A07DACC8227/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Apr  7 07:16:53.435: //2750/7A07DACC8227/CCAPI/ccCallSetContext:
   Context=0x49DB548C
Apr  7 07:16:53.435: //2745/7A07DACC8227/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:53.439: //2725/6EE13D3F8220/CCAPI/cc_api_call_disconnect_done:
   Disposu aition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2725,
Apr  7 07:16:53.439: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:53.439: :cc_free_feature_vsa freeing 486C02F0
Apr  7 07:16:53.439:  vsacount in free is 18
Apr  7 07:16:53.439: //2726/70C5DD368221/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2726,
Apr  7 07:16:53.443: //2726/70C5DD368221/CCAPI/cc_api_call_disconnect_done:
Apr  7 07:16:53.443: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:53.443: :cc_free_feature_vsa freeing 486C0210
Apr  7 07:16:53.443:  vsacount in free is 17
Apr  7 07:16:53.783: //2729/72AB17E88222/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2729
Apr  7 07:16:53.787: //2731/72AB17E88222/CCAPI/ccCallDisconnect:
Apr  7 07:16:53.787: //2731/72AB17E88222/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:53.803: //2729/72AB17E88222/CCAPI/ccCallDisconnect:
Apr  7 07:16:53.803: //2729/72AB17E88222/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:53.807: //2750/7A07DACC8227/CCAPI/cc_api_call_proceeding:
Apr  7 07:16:53.807: //-1/7C89F1AE8229/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771135
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:53.811: //-1/7C89F1AE8229/CCAPI/cc_api_call_setup_ind_common:
Apr  7 07:16:53.811: //-1/7C89F1AE8229/CCAPI/ccCheckClipClir:
   In: Calling Number=1147771100(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=1147771100(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Apr  7 07:16:53.811: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:53.811: :cc_get_feature_vsa malloc success
Apr  7 07:16:53.811:  cc_get_feature_vsa count is 18
Apr  7 07:16:53.811: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215037976,feature_id:2751
Apr  7 07:16:53.811: //2751/7C89F1AE8229/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1147771100(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Apr  7 07:16:53.815: //2751/7C89F1AE8229/CCAPI/cc_process_call_setup_ind:
   Event=0x49117EE0
Apr  7 07:16:53.815: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Apr  7 07:16:53.815: //2751/7C89F1AE8229/CCAPI/ccCallSetContext:
   Context=0x49DBCA8C
   >>>>CCAPI handed cid 2751 with tag 2 to app "_ManagedAppProcess_Default"
Apr  7 07:16:53.819: //2751/7C89F1AE8229/CCAPI/ccCallProceeding:
Apr  7 07:16:53.823: //2751/7C89F1AE8229/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=3, Params=0x4A087D98, Progress Indication=NULL(0)
Apr  7 07:16:53.823: //2751/7C89F1AE8229/CCAPI/ccCheckClipClir:
   Guid=7C89F1AE-7FB8-11E1-8229-001E7A5E63D8, Outgoing Dial-peer=3
Apr  7 07:16:53.823: //2751/7C89F1AE8229/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=47771135
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apr  7 07:16:53.823: //2751/7C89F1AE8229/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=1147771100,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Apr  7 07:16:53.823: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr  7 07:16:53.823: :cc_get_feature_vsa malloc success
Apr  7 07:16:53.823:  cc_get_feature_vsa count is 19
Apr  7 07:16:53.823: :FEATURE_VSA attributes are: feature_name:0,feature_time:1215038200,feature_id:2752
Apr  7 07:16:53.823: //2752/7C89F1AE8229/CCAPI/ccIFCallSetupRequestPrivate:
Apr  7 07:16:53.827: //2752/7C89F1AE8229/CCAPI/ccCallSetContext:
   Context=0x4A087D48
Apr  7 07:16:53.827: //2751/7C89F1AE8229/CCAPI/ccSaveDialpeerTag:
Apr  7 07:16:53.835: //2728/70C5DD368221/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2728,
Apr  7 07:16:53.835: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:53.835: :cc_free_feature_vsa freeing 486C0130
Apr  7 07:16:53.835:  vsacount in free is 18
Apr  7 07:16:53.835: //2729/72AB17E88222/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2729,
Apr  7 07:16:53.835: :cc_free_feature_vsa freeing 486C0050
Apr  7 07:16:53.835:  vsacount in free is 17
Apr  7 07:16:54.627: //2732/74E045C88223/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2732
Apr  7 07:16:54.635: //2736/74E045C88223/CCAPI/ccCallDisconnect:
Apr  7 07:16:54.635: //2736/74E045C88223/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:54.683: //2732/74E045C88223/CCAPI/ccCallDisconnect:
Apr  7 07:16:54.687: //2732/74E045C88223/CCAPI/ccCallDisconnect:
Apr  7 07:16:54.687: //2732/74E045C88223/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:54.695: //2731/72AB17E88222/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2731,
Apr  7 07:16:54.695: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:54.695: :cc_free_feature_vsa freeing 486BFF70
Apr  7 07:16:54.695:  vsacount in free is 16
Apr  7 07:16:54.695: //2732/74E045C88223/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2732,
Apr  7 07:16:54.695: :cc_free_feature_vsa freeing 486C09F0
Apr  7 07:16:54.699:  vsacount in free is 15
Apr  7 07:16ll
All possible debugging has been turned off
VG2811#:55.335: //2737/774F72DE8224/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2737
Apr  7 07:16:55.335: //2737/774F72DE8224/CCAPI/cc_api_call_disconnected:
Apr  7 07:16:55.339: //2741/774F72DE8224/CCAPI/ccCallDisconnect:
Apr  7 07:16:55.339: //2741/774F72DE8224/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:55.351: //2737/774F72DE8224/CCAPI/ccCallDisconnect:
Apr  7 07:16:55.351: //2737/774F72DE8224/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:55.363: //2736/74E045C88223/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2736,
Apr  7 07:16:55.363: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:55.363: :cc_free_feature_vsa freeing 486C0AD0
Apr  7 07:16:55.363:  vsacount in free is 14
Apr  7 07:16:55.363: //2737/774F72DE8224/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49A28CC0, Tag=0x0, Call Id=2737,
Apr  7 07:16:55.367: //2737/774F72DE8224/CCAPI/cc_api_call_disconnect_done:
Apr  7 07:16:55.367: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr  7 07:16:55.367: :cc_free_feature_vsa freeing 486BFCD0
Apr  7 07:16:55.367:  vsacount in free is 13
Apr  7 07:16:56.135: //2742/79CDE0388226/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x49A28CC0, Call Id=2742
Apr  7 07:16:56.139: //2747/79CDE0388226/CCAPI/ccCallDisconnect:
Apr  7 07:16:56.139: //2747/79CDE0388226/CCAPI/cc_api_get_transfer_info:
Apr  7 07:16:56.143: //2749/7BC1C0738228/CCAPI/cc_api_call_disconnected:
   Cause Value=38, Interface=0x48DDE448, Call Id=2749
Apr  7 07:16:56.191: //2742/79CDE0388226/CCAPI/ccCallDisconnect:
   tCause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
Apr  7 07:16:56.191: //2742/79CDE0388226/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Nullerm no mon
Pawan Arora
Your debug shows a loop.
This is the sequence of a call:
1) Calling Number=9899525346
cc_api_call_disconnected Cause Value=38, Interface=0x48DDE448, Call Id=2715
The call fails on DP 3 and so uses the DP 9. The DP 9 uses a pots port that changes the calling number.
2)Calling Number=1147771100
cc_api_call_disconnected Cause Value=38, Interface=0x48DDE448, Call Id=2718
loop
3)Calling Number=1147771100
cc_api_call_disconnected Cause Value=38, Interface=0x48DDE448, Call Id=2721
loop between dp 3 e 9
cc_api_call_disconnected Cause Value=102, Interface=0x49A28CC0, Call Id=2732
These are the disconnection cause code:
38 Signaling socket failure or Network out of order
102 Call setup timeout
If you want stop the loop you must add the command "huntstop" to DP 3. In this way if a call fails on DP 3 no hunting procedure starts.
To understand why a call sometimes fails on DP 3 you must investigate in your net.
What is the host 192.168.10.230? Is always reachable? Can handle your load?
Regards.
Thanks Daniele for the information, i will try to stop the hunting on monday. By the way host 192.168.10.230 is my call manager and it is always reachable.
