12-06-2017 03:56 AM - edited 03-17-2019 11:44 AM
Good day,
I having the following scheme.
CUCM<=>VG224 <=> VIC2-FXO4*2921<=>CP7911(SIP)
CUCM and VG224 are customer managed, so cannot be debugged or reconfigured.
Customer provides 6 analog lines.
The problem is that any call coming to voice-port 0/0/2 is dropped upon picking the handset.
Tried to swap 2 physical lines between each other to check if problem lays within FSX on VG224 - same result, calls to voice-port 0/0/2 are dropped on answer.
Checked FXO card on another 2811 router - all ports of the card are receiving and placing calls.
Replaced the card with the same one - again, all calls to voice-port 0/0/2 are dropped.
Meanwhile, outgoing calls through this port are working fine.
Also tried different IOS versions 155-3.M6, 155-3.M6a, 154-3.M8 and 153-3.M10
Phones are currently configured to use SIP, however rebuilding the system to SCCP didn't give any result. So, moved back to SIP as phones are living on different subnets. Also tried a Snom370 phone.
Attached are config and debugs of my 2921. Note, currently all connection plar are set to 166077 for testing.
Please help. I end up with searching where the problem is.
Solved! Go to Solution.
12-06-2017 05:11 AM
12-06-2017 04:17 AM
12-06-2017 04:33 AM
voice-port 0/0/2
signal groundStart
connection plar opx 166077
didn't work.
12-06-2017 04:38 AM
I don't see any error in your configuration. Debug logs suggest a port error. I know that you have tried this card to another router and it works properly, but to be sure I would suggest these:
- swap the two FXO cards
- try use another HWIC slot on the 2921 router; i.e. move FXO card from slot 0 to slot 2 ot 3.
12-07-2017 01:59 AM
Will check with HWIC slot change next week as currently cannot get to site.
12-06-2017 04:46 AM
Please try configuring "no battery-reversal"under voice port as it can also disconnect calls. If it still fails please collect debug vpm signal and debug voip ccapi inout with the command configured.
12-06-2017 04:58 AM
12-06-2017 05:11 AM
12-06-2017 09:16 PM
Sorry for delay, tried as you suggested this morning and everything went fine.
voice-port 0/0/2
supervisory disconnect dualtone mid-call
no battery-reversal
So, do I need to set it on all ports or there is some hardware problem on 2921?
12-06-2017 10:27 PM
12-06-2017 11:16 PM
Changing configuration on one port should not effect other ports. The call was disconnected from VG224 side as you can see FXO received (E_DSP_SIG) a disconnect signal.
[0/0/2, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
Is it possible to get logs from VG224? Please collect logs together not separately
debug voice application stcapp
debug vpm signal
12-07-2017 02:30 AM
In general, current state of the system is acceptable as these lines are to be used over VSAT link on the vessels as a reserve for two other DID lines from another provider, therefore rare use is expected.
Thanks a lot for your help.
12-06-2017 09:19 PM
12-06-2017 11:24 PM
