Incoming calling party settings  Trunk
elite2010
Level 3
Level 3
If I want to change   + 12345678 to 6678 ,  how can I do that ,
I Can’t find a translation pattern there
7 Replies 7
Leo Laohoo
This line of questioning has already been answered in your previous thread (LINK).
Thanks for the reply ,
since there is no transform mask under incoming calling party settings , In that case what is the solution
Is there any reason you dont want to use a Translation Pattern?
RP                  + 123456.78
Discard Digits: Predot
Prefix Digits:    66
George
Hope the above helps,
gsotirop
No problem of using translation pattern , but under trunk , calling party there is no option to use translation pattern for incoming calls from pstn ?
Adding translation pattern and  under a css and assign the css  here  will solve the issue ?
