Incoming calls - busy signal - Viatalk
k.scholtens
My set up is an ISR 2901 with CME 10.5 with Viatalk
Outgoing calls are working as expected.   Incoming calls receive a busy signal.  Further to this, there is no traffic to the interface.  The voip ports are in fact opened to the world, so I know firewalls are not a problem.
SIP call tracing (debug voip ccapi inout) shows no activity to my ISR 2901 when inbound calls are made.
ISGNAV01#show dialplan number 100
Macro Exp.: 100
VoiceEncapPeer20004
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `',
        tag = 20004, destination-pattern = `100$',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 20004, Admin state is up, Operation state is up,
        incoming called-number = `',
connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        Destination route-string = None
        huntstop = enabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        mailbox selection policy: none
        type = pots, prefix = `',
        forward-digits 0
        session-target = `', voice-port = `50/0/1',
        direct-inward-dial = disabled,
        digit_strip = enabled,
        register E.164 number with H323 GK and/or SIP Registrar = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        preemption level = `routine'
        bandwidth:
            maximum = 64 KBits/sec, minimum = 64 KBits/sec
        voice class called-number:
            inbound = `', outbound = `'
        dial tone generation after remote onhook = enabled
        mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
        snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 614621, Charged Units = 0,
        Successful Calls = 1, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 28, Refused Calls = 4,
        Last Disconnect Cause is "10  ",
        Last Disconnect Text is "normal call clearing (16)",
        Last Setup Time = 44075118.
        Last Disconnect Time = 44090810.
Matched: 100   Digits: 4   Matched pattern: 100$ Preference: 0
Target:
Running config
Current configuration : 7469 bytes
! Last configuration change at 15:17:00 PST Mon Mar 2 2015
! NVRAM config last updated at 13:26:38 PST Mon Mar 2 2015
version 15.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service internal
service sequence-numbers
hostname ISGNAV01
boot-start-marker
boot system flash0:/c2900-universalk9-mz.SPA.154-3.M2.bin
boot-end-marker
logging buffered 2500000
no logging console
no logging monitor
aaa new-model
aaa session-id common
clock timezone PST -8 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
ip dhcp excluded-address 172.16.30.1
ip dhcp excluded-address 172.16.30.2
ip dhcp excluded-address 172.16.30.3
ip dhcp excluded-address 172.16.30.4
ip dhcp excluded-address 172.16.30.10
ip dhcp pool VOICE-INT
 import all
 network 172.16.30.0 255.255.255.0
 default-router 172.16.30.1
 dns-server 75.75.75.75 8.8.8.8
 option 150 ip 172.16.30.1
ip dhcp pool static_APNAVO
 host 172.16.30.2 255.255.255.0
 client-identifier 0188.5a92.bc45.53
ip dhcp pool static_APNAVB
 host 172.16.30.3 255.255.255.0
 client-identifier 0124.e9b3.7839.98
ip dhcp pool static_APNAVT
 host 172.16.30.4 255.255.255.0
 client-identifier 0124.e9b3.7839.87
ip domain name chilloutroom.net
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
voice service voip
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  rel1xx disable
  registrar server expires max 3600 min 3600
  no update-callerid
  authenticate redirecting-number
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
voice iec syslog
license udi pid CISCO2901/K9 sn FTX150202M8
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
file privilege 0
username kurt privilege 15 password 7 06085D355E47190A
redundancy
 notification-timer 120000
ip ssh time-out 60
ip ssh authentication-retries 2
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ES_LAN$
 ip address 172.16.30.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address XX.XX.XXX.XXX 255.255.255.248
 ip access-group 150 in
 ip nat outside
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash0:/CME
ip nat inside source list 100 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 XX.XX.XXX.XXX
logging trap debugging
tftp-server flash0:/phone/7925G/APPSH-1.4.6.3.SBN alias APPSH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/CP7925G-1.4.6.3.LOADS alias CP7925G-1.4.6.3.LOADS
tftp-server flash0:/phone/7925G/GUIH-1.4.6.3.SBN alias GUIH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/JSYSH-1.4.6.3.SBN alias JSYSH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/SYSH-1.4.6.3.SBN alias SYSH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/JUIH-1.4.6.3.SBN alias JUIH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/TNUXH-1.4.6.3.SBN alias TNUXH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/TNUXRH-1.4.6.3.SBN alias TNUXRH-1.4.6.3.SBN
tftp-server flash0:/phone/7925G/WLANH-1.4.6.3.SBN alias WLANH-1.4.6.3.SBN
tftp-server flash0:/phone/7975/apps75.9-4-2TH1-1.sbn alias apps75.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/cnu75.9-4-2TH1-1.sbn alias cnu75.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/cvm75sccp.9-4-2TH1-1.sbn alias cvm75sccp.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/dsp75.9-4-2TH1-1.sbn alias dsp75.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/jar75sccp.9-4-2TH1-1.sbn alias jar75sccp.9-4-2TH1-1.sbn
tftp-server flash0:/phone/7975/SCCP75.9-4-2-1S.loads alias SCCP75.9-4-2-1S.loads
access-list 150 permit ip XX.XX.XXX.XXX 0.0.0.7 any
access-list 150 permit udp any host XX.XX.XXX.XXX eq tftp
access-list 150 permit udp any host XX.XX.XXX.XXX eq 5060
access-list 150 permit udp any host XX.XX.XXX.XXX eq 5061
access-list 150 permit udp any host XX.XX.XXX.XXX range 10000 20000
access-list 150 permit udp any host XX.XX.XXX.XXX range 35000 65000
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 voip
 description **Incoming Call from SIP Trunk VIATALK**
 session protocol sipv2
 session target sip-server
 incoming called-number .
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 no vad
dial-peer voice 2 voip
 description **Outgoing Call to SIP VIATALK**
 destination-pattern [2-9]..[2-9]......
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 3 voip
 destination-pattern 1[2-9]..[2-9]......
 dtmf-relay sip-notify rtp-nte
 codec g711ulaw
dial-peer voice 4 voip
 description **Outgoing Call to SIP VIATALK** (1+ long distance dialing)
 destination-pattern 1..........
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
sip-ua
 authentication username 19255551212 password 7 ABCDEFGHIJKLMNOPQRST
 no remote-party-id
 retry invite 4
 retry response 3
 retry bye 2
 retry cancel 2
 retry register 10
 timers register 250
 mwi-server dns:slingshot.vtnoc.net expires 300 port 5060 transport udp unsolicited
 registrar dns:slingshot.vtnoc.net expires 3600
 sip-server dns:slingshot.vtnoc.net:5060
 host-registrar
gatekeeper
 shutdown
telephony-service
 no auto-reg-ephone
 max-ephones 10
 max-dn 20
 ip source-address 172.16.30.1 port 2000
 system message TELEPHONY by Concord Telesys
 url services http://www.singlewire.com/freeservices/menu
 cnf-file location flash:
 cnf-file perphone
 load 7925 CP7925G-1.4.6.3.LOADS
 load 7975 SCCP75.9-4-2-1S.loads
 max-conferences 8 gain -6
 web admin system name kurt secret 5 $1$wT4J$KZ0z/11hRsX7XLJpo8kZU/
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
 number 100
 label Office
 name Office
ephone-dn  2  dual-line
 number 101
 label LivingRoom
 name LivingRoom
ephone  1
 device-security-mode none
 description Home Office
 mac-address E05F.B9BC.2C91
 max-calls-per-button 4
 type 7925
 button  1:2
ephone  2
 mac-address 0022.905C.6DDE
 type 7975
 button  1:1 2m2
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 transport input ssh
scheduler allocate 20000 1000
ntp server us.pool.ntp.org
end
5 Replies 5
Terry Cheema
Can you make  a test call and post the output of "debug voip ccapi inout"
and also post the calling and called numbers.
-Terry
Hi Terry -
The 925XXXXXXX was placing a call to 925XXXXXXX. These outbound calls work. The inbound calls to 925XXXXXXX, do not. That is the one getting the busy signal. Thanks for your help.
010285: .Mar 2 22:12:12.589: //-1/1107607B829B/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=100
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
010286: .Mar 2 22:12:12.589: //-1/1107607B829B/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2416DF80, Call Info(
Calling Number=100,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20004, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
010287: .Mar 2 22:12:12.589: //-1/1107607B829B/CCAPI/ccCheckClipClir:
In: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
010288: .Mar 2 22:12:12.589: //-1/1107607B829B/CCAPI/ccCheckClipClir:
Out: Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
010289: .Mar 2 22:12:12.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010290: .Mar 2 22:12:12.589: :cc_get_feature_vsa malloc success
010291: .Mar 2 22:12:12.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010292: .Mar 2 22:12:12.589: cc_get_feature_vsa count is 1
010293: .Mar 2 22:12:12.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010294: .Mar 2 22:12:12.589: :FEATURE_VSA attributes are: feature_name:0,feature_time:617749624,feature_id:175
010295: .Mar 2 22:12:12.589: //595/1107607B829B/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=100(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
010296: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/cc_process_call_setup_ind:
Event=0x22BA05D0
010297: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/ccCallSetContext:
Context=0x2456785C
010298: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 595 with tag 20004 to app "_ManagedAppProcess_Default"
010299: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/ccCallSetupAck:
Call Id=595
010300: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
010301: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=595
010302: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
010303: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
010304: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/ccCallReportDigits:
(callID=0x253, digit_event=0x1, enable=TRUE, consume=FALSE)
010305: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=595
010306: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2416DF80, callID=0x253, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
010307: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x2416DF80, Call Id=595
010308: .Mar 2 22:12:12.593: //595/1107607B829B/CCAPI/cc_api_call_report_digits_done:
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
010309: .Mar 2 22:12:13.033: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=595, Digit=1, DigitBeginFlags=0x0,
Rtp Timestamp=0xD6E7A0, Rtp Expiration=0x0
010310: .Mar 2 22:12:13.033: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
Source Call Id=595, Digit=1, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
010311: .Mar 2 22:12:13.033: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
Call Entry(Handoff Depth=0)
010312: .Mar 2 22:12:13.233: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Source Call Id=595, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0xD764A0, Rtp Expiration=0x0
010313: .Mar 2 22:12:13.233: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
Source Call Id=595, Digit=9, Duration=100,
010314: .Mar 2 22:12:13.233: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010315: .Mar 2 22:12:13.433: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Source Call Id=595, Digit=2, DigitBeginFlags=0x0,
Rtp Timestamp=0xD7E1A0, Rtp Expiration=0x0
010316: .Mar 2 22:12:13.433: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
Source Call Id=595, Digit=2, Duration=100,
010317: .Mar 2 22:12:13.433: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010318: .Mar 2 22:12:13.633: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Source Call Id=595, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0xD85EA0, Rtp Expiration=0x0
010319: .Mar 2 22:12:13.633: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
Source Call Id=595, Digit=5, Duration=100,
010320: .Mar 2 22:12:13.633: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010321: .Mar 2 22:12:13.833: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xD8DBA0, Rtp Expiration=0x0
010322: .Mar 2 22:12:13.833: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010323: .Mar 2 22:12:13.833: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010324: .Mar 2 22:12:14.033: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xD958A0, Rtp Expiration=0x0
010325: .Mar 2 22:12:14.033: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010326: .Mar 2 22:12:14.033: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010327: .Mar 2 22:12:14.233: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xD9D5A0, Rtp Expiration=0x0
010328: .Mar 2 22:12:14.233: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010329: .Mar 2 22:12:14.233: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010330: .Mar 2 22:12:14.433: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Source Call Id=595, Digit=0, DigitBeginFlags=0x0,
Rtp Timestamp=0xDA52A0, Rtp Expiration=0x0
010331: .Mar 2 22:12:14.433: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
Source Call Id=595, Digit=0, Duration=100,
010332: .Mar 2 22:12:14.433: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010333: .Mar 2 22:12:14.633: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xDACFA0, Rtp Expiration=0x0
010334: .Mar 2 22:12:14.633: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010335: .Mar 2 22:12:14.633: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010336: .Mar 2 22:12:14.833: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Source Call Id=595, Digit=6, DigitBeginFlags=0x0,
Rtp Timestamp=0xDB4CA0, Rtp Expiration=0x0
010337: .Mar 2 22:12:14.833: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
Source Call Id=595, Digit=6, Duration=100,
010338: .Mar 2 22:12:14.833: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010339: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0xDBC9A0, Rtp Expiration=0x0
010340: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010341: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/cc_api_call_digit_end:
010342: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccCallReportDigits:
(callID=0x253, digit_event=0x0, enable=FALSE, consume=FALSE)
010343: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccCallReportDigits:
010344: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x2416DF80, callID=0x253, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
010345: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/cc_api_call_report_digits_done:
010346: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/cc_api_call_report_digits_done:
010347: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
010348: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3, Params=0x2456CF4C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
010349: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccCheckClipClir:
010350: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccCheckClipClir:
010351: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccCallSetupRequest:
Destination Pattern=1[2-9]..[2-9]......, Called Number=1925XXXXXXX, Digit Strip=FALSE
010352: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccCallSetupRequest:
Called Number=1925XXXXXXX(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Office
Account Number=, Final Destination Flag=FALSE,
Guid=1107607B-C0A3-11E4-829B-ECAB8E7838B0, Outgoing Dial-peer=3
010353: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=100
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=1925XXXXXXX
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
010354: .Mar 2 22:12:15.033: //595/1107607B829B/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3EBE699C, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=100,(Calling Name=Office)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=1925XXXXXXX(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=3, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
010355: .Mar 2 22:12:15.033: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010356: .Mar 2 22:12:15.033: :cc_get_feature_vsa malloc success
010357: .Mar 2 22:12:15.033: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010358: .Mar 2 22:12:15.033: cc_get_feature_vsa count is 2
010359: .Mar 2 22:12:15.033: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
010360: .Mar 2 22:12:15.033: :FEATURE_VSA attributes are: feature_name:0,feature_time:617749848,feature_id:176
010361: .Mar 2 22:12:15.037: //596/1107607B829B/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
010362: .Mar 2 22:12:15.037: //596/1107607B829B/CCAPI/ccCallSetContext:
Context=0x2456CEFC
010363: .Mar 2 22:12:15.037: //595/1107607B829B/CCAPI/ccSaveDialpeerTag:
010364: .Mar 2 22:12:15.037: //596/1107607B829B/CCAPI/cc_api_call_proceeding:
Interface=0x3EBE699C, Progress Indication=NULL(0)
010365: .Mar 2 22:12:15.057: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1925XXXXXXX@slingshot.vtnoc.net:5060 SIP/2.0
Via: SIP/2.0/UDP XX.XX.XXX.XXX:5060;branch=z9hG4bK3C5453
From: "Office" <sip:100@slingshot.vtnoc.net>;tag=1B85ED7C-C4D
To: <sip:1925XXXXXXX@slingshot.vtnoc.net>
Date: Tue, 03 Mar 2015 06:12:15 GMT
Call-ID: 127D8615-C0A311E4-82A0ECAB-8E7838B0@XX.XX.XXX.XXX
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0285696123-3231912420-2191256747-2390243504
User-Agent: Cisco-SIPGateway/IOS-15.4.3.M2
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1425363135
Contact: <sip:100@XX.XX.XXX.XXX:5060>
Call-Info: <sip:XX.XX.XXX.XXX:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 274
v=0
o=CiscoSystemsSIP-GW-UserAgent 4637 4342 IN IP4 XX.XX.XXX.XXX
s=SIP Call
c=IN IP4 XX.XX.XXX.XXX
t=0 0
m=audio 16628 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
010366: .Mar 2 22:12:15.077: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP XX.XX.XXX.XXX:5060;received=XX.XX.XXX.XXX;rport=61435;branch=z9hG4bK3C5453
To: <sip:1925XXXXXXXX@slingshot.vtnoc.net>
CSeq: 101 INVITE
Server: OpenSIPS (1.8.5-tls (x86_64/linux))
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25662 req_src_ip=XX.XX.XXX.XXX req_src_port=61435 in_uri=sip:1925XXXXXXX@slingshot.vtnoc.net:5060 out_uri=sip:1925XXXXXX@slings"
010367: .Mar 2 22:12:15.077: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
To: <sip:1925XXXXXXX@slingshot.vtnoc.net>;tag=1b73745810345c25dc91027d595549ab.e5fa
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="slingshot.vtnoc.net", nonce="54f550dc00001af174cb56af360561dd89888803ad83c534", qop="auth"
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25662 req_src_ip=XX.XX.XXX.XXX req_src_port=61435 in_uri=sip:1925XXXXXXX@slingshot.vtnoc.net:5060 out_uri=sip:1925XXXXXXX@slings"
010368: .Mar 2 22:12:15.081: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1925XXXXXXX@slingshot.vtnoc.net:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
010369: .Mar 2 22:12:15.081: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP XX.XX.XXX.XXX:5060;branch=z9hG4bK3C614E0
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="1925XXXXXXX",realm="slingshot.vtnoc.net",uri="sip:1925XXXXXXXX@slingshot.vtnoc.net:5060",response="9f6be8a22a46c766f5ec690b68af2510",nonce="54f550dc01
Content-Length: 274
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
010370: .Mar 2 22:12:15.101: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP XX.XX.XXX.XXX:5060;received=XX.XX.XXX.XXX;rport=61435;branch=z9hG4bK3C614E0
To: <sip:19252XXXXXXX@slingshot.vtnoc.net>
CSeq: 102 INVITE
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25660 req_src_ip=XX.XX.XXX.XXX req_src_port=61435 in_uri=sip:1925XXXXXXX@slingshot.vtnoc.net:5060 out_uri=sip:1925XXXXXXX@slings"
010371: .Mar 2 22:12:15.129: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Giving a try
CSeq: 102 INVITE
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25660 req_src_ip=XX.XX.XXX.XXX req_src_port=61435 in_uri=sip:1925XXXXXXX@slingshot.vtnoc.net:5060 out_uri=sip:+1925XXXXXXX@216.2"
010372: .Mar 2 22:12:16.417: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP XX.XX.XXX.XXX:5060;rport=61435;received=XX.XX.XXX.XXX;branch=z9hG4bK3C614E0
To: <sip:+1925XXXXXXX@slingshot.vtnoc.net>;tag=gK07c553f8
CSeq: 102 INVITE
Record-Route: <sip:216.246.37.202:5060;lr;ftag=1B85ED7C-C4D>
Record-Route: <sip:198.8.63.63:5060;lr;ftag=1B85ED7C-C4D;vsf=AAAAABoBCXJGWFtXVkRaWzRdGh0ACBBGARFadnRub2MubmV0>
Contact: <sip:+1925XXXXXXX@4.55.8.225:5060>
Allow: INVITE,ACK,CANCEL,BYE,PRACK,UPDATE
Content-Length: 232
Content-Disposition: session; handling=required
v=0
o=Sonus_UAC 22353 15955 IN IP4 4.55.8.225
s=SIP Media Capabilities
c=IN IP4 4.55.8.194
t=0 0
m=audio 17440 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
010373: .Mar 2 22:12:16.421: //596/1107607B829B/CCAPI/cc_api_call_alert:
Interface=0x3EBE699C, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
010374: .Mar 2 22:12:16.421: //596/1107607B829B/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
010375: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/ccCallAlert:
010376: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
010377: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID1=0x253, gcid=1107607B-C0A311E4-829BECAB-8E7838B0, tag=0x0)
010378: .Mar 2 22:12:16.421: //596/1107607B829B/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFF, callID2=0x254, gcid=1107607B-C0A311E4-829BECAB-8E7838B0, tag=0x0)
010379: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFF, Call Id1=595, Call Id2=596, Tag=0x0
010380: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/cc_api_bridge_done:
Conference Id=0x32, Source Interface=0x2416DF80, Source Call Id=595,
Destination Call Id=596, Disposition=0x0, Tag=0xFFFFFFFF
010381: .Mar 2 22:12:16.421: //596/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
010382: .Mar 2 22:12:16.421: cc_api_get_xcode_stream : 4982
010383: .Mar 2 22:12:16.421: //596/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
010384: .Mar 2 22:12:16.421: cc_api_get_xcode_stream : 4982
010385: .Mar 2 22:12:16.421: //596/1107607B829B/CCAPI/cc_api_bridge_done:
Conference Id=0x32, Source Interface=0x3EBE699C, Source Call Id=596,
Destination Call Id=595, Disposition=0x0, Tag=0x0
010386: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/cc_generic_bridge_done:
010387: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x32, Destination Call Id=596)
010388: .Mar 2 22:12:16.421: //596/1107607B829B/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x32, Destination Call Id=595)
010389: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/ccConferenceCreate:
010390: .Mar 2 22:12:16.421: confID:0x32; callEntry1 callID1:0x253, type:6; callEntry2 callID2:0x254, type:3
010391: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/cc_api_caps_ind:
Destination Interface=0x3EBE699C, Destination Call Id=596, Source Call Id=595,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=20, Signal Type=3)
010392: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
010393: .Mar 2 22:12:16.421: //596/1107607B829B/CCAPI/cc_api_caps_ind:
Destination Interface=0x2416DF80, Destination Call Id=595, Source Call Id=596,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
Modem=0x0, Codec Bytes=160, Signal Type=2)
010394: .Mar 2 22:12:16.421: //596/1107607B829B/CCAPI/cc_api_caps_ind:
010395: .Mar 2 22:12:16.421: //596/1107607B829B/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=ON(0x2),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1270)
010396: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/cc_api_caps_ack:
010397: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/ccCallFeature:
Feature Type=25, Call Id=595
010398: .Mar 2 22:12:16.421: //595/1107607B829B/CCAPI/ccCallFeature:
010399: .Mar 2 22:12:16.425: //595/1107607B829B/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x32, Call Id1=595, Call Id2=596
010400: .Mar 2 22:12:16.425: //595/1107607B829B/CCAPI/cc_api_voice_mode_event:
Call Id=595
010401: .Mar 2 22:12:16.425: //595/1107607B829B/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x2456785C)
010402: .Mar 2 22:12:32.433: //595/1107607B829B/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x2416DF80, Call Id=595
010403: .Mar 2 22:12:32.433: //595/1107607B829B/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
010404: .Mar 2 22:12:32.433: //595/1107607B829B/CCAPI/ccConferenceDestroy:
Conference Id=0x32, Tag=0x0
010405: .Mar 2 22:12:32.433: //595/1107607B829B/CCAPI/ccConferenceDestroy:
010406: .Mar 2 22:12:32.433: confID:0x32; callEntry1 callID1:0x253, type:6; callEntry2 callID2:0x254, type:3
010407: .Mar 2 22:12:32.433: //595/1107607B829B/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=596, Disposition=0x0, Tag=0x0
010408: .Mar 2 22:12:32.433: //596/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
010409: .Mar 2 22:12:32.433: cc_api_get_xcode_stream : 4982
010410: .Mar 2 22:12:32.433: //595/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
010411: .Mar 2 22:12:32.433: cc_api_get_xcode_stream : 4982
010412: .Mar 2 22:12:32.433: //596/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
010413: .Mar 2 22:12:32.433: cc_api_get_xcode_stream : 4982
010414: .Mar 2 22:12:32.433: //596/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
010415: .Mar 2 22:12:32.433: cc_api_get_xcode_stream : 4982
010416: .Mar 2 22:12:32.433: //596/1107607B829B/CCAPI/cc_api_bridge_drop_done:
010417: .Mar 2 22:12:32.433: //595/1107607B829B/CCAPI/cc_generic_bridge_done:
010418: .Mar 2 22:12:32.433: //596/1107607B829B/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
010419: .Mar 2 22:12:32.433: //596/1107607B829B/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
010420: .Mar 2 22:12:32.437: //595/1107607B829B/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
010421: .Mar 2 22:12:32.437: //595/1107607B829B/CCAPI/ccCallDisconnect:
010422: .Mar 2 22:12:32.437: //595/1107607B829B/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
010423: .Mar 2 22:12:32.437: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:1925XXXXXXX@slingshot.vtnoc.net:5060 SIP/2.0
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1425363152
Reason: Q.850;cause=16
Content-Length: 0
010424: .Mar 2 22:12:32.437: //595/1107607B829B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2416DF80, Tag=0x0, Call Id=595,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
010425: .Mar 2 22:12:32.437: //595/1107607B829B/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
010426: .Mar 2 22:12:32.437: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
010427: .Mar 2 22:12:32.437: :cc_free_feature_vsa freeing 24D21C70
010428: .Mar 2 22:12:32.437: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
010429: .Mar 2 22:12:32.437: vsacount in free is 1
010430: .Mar 2 22:12:32.465: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 canceling
To: <sip:1925XXXXXXX@slingshot.vtnoc.net>;tag=0e617f3419f967f79f34a07c459caad4-cf7f
CSeq: 102 CANCEL
Content-Length: 0
Warning: 392 198.8.63.63:5060 "Noisy feedback tells: pid=25666 req_src_ip=XX.XX.XXX.XXX req_src_port=61435 in_uri=sip:1925XXXXXXX@slingshot.vtnoc.net:5060 out_uri=sip:1925XXXXXXX@slings"
010431: .Mar 2 22:12:32.469: //596/1107607B829B/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3EBE699C, Tag=0x0, Call Id=596,
010432: .Mar 2 22:12:32.469: //596/1107607B829B/CCAPI/cc_api_call_disconnect_done:
010433: .Mar 2 22:12:32.469: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
010434: .Mar 2 22:12:32.469: :cc_free_feature_vsa freeing 24D21D50
010435: .Mar 2 22:12:32.469: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
010436: .Mar 2 22:12:32.469: vsacount in free is 0
010437: .Mar 2 22:12:32.585: //596/1107607B829B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 102 INVITE
Content-Length: 0
010438: .Mar 2 22:12:32.585: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Also, sorry if I didn't make it clear, I did try enabling debug for the inbound calls and nothing is logged.  I think I even tried an interface dump during ACL builds and no traffic even attempts to try to get to the router from viatalk.
Hmm then it may be something to do with the provider - did you check with them?
Also confirm your NAT is working, quickly glanced through cant see your ACL 100.
-Terry
Hi Terry - ok, that is a good observation.  With that in mind, how should the ACLs be applied for CME?.  My assumption was everything should be on the egress interface.  Can you please review my NAT configuration to ensure it looks correct (besides the ACL problem).  Thank you.
There are a number of configuration examples for Viatalk working.  I stumbled across this NAT example, that uses VLANs:
http://noonforum.com/archives/5
Do you have any examples of good working setups with NATs and ACLs applied for CME on a dual-faced router like mine?  Thanks
