Incoming calls reach VG but IP Phones doesn't ring
Mohamed AATIF
Hi guys,
I have an issue with incoming calls, when I make a call from an external phone I hear a ringtone but the IP Phone doesn't ring
Any help please
Thank you
Chris Deren
You router configuration has no voice config in it, where is the call suppose to go and on which voice-port is it arriving? The voice port needs plar config to send it to a specific number and then depending on call processing system you are using you need config i.e. dial-peers to point to it.
avinsrid89
Sep  3 13:35:17.623: //39/72F1C2848057/CCAPI/ccCallDisconnect:
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
You have a call coming in to 305 and disconnecting with cause value 1 which means destination not found. This is a dial plan issue.
Is the call supposed to go to another device or a phone that is registered on this router (CME) ? I don't see any ephone configurations on this router.
Where is this call supposed to go? The call will be accepted on incoming dial peer however, without a dial peer.
Kindly rate useful posts!
~Avinash
