01-09-2018 06:05 PM - edited 03-17-2019 11:54 AM
A little background. I have a 2811 at a client site setup with a single sip trunk. It worked at the client's old site. It no longer accepts inbound calls Nothing has been changed in terms of the config. I have a 2851 at home as a lab. I had it as a mirror with my own SIP account. It too was working. It no longer receives calls after been stood up again to troubleshoot the client. Behind the main internet connection at the lab are an SPA112 which receives calls just fine from the same server and voip provider. A soft phone is also able to receive calls using the same account as is configured on the 2851. It leads me to think that I have missed something on the 2811 and the 2851 I could really us a hand please and thank you:
SHOW RUN for the SIP section sanitized:
voice service voip
ip address trusted list
ipv4 184.75.215.146
ipv4 10.10.153.1
ip address trusted call-block cause not-in-cug
gcid
clid substitute name
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
session refresh
e911
transport switch udp tcp
asserted-id ppi
localhost dns:phones.iisottawa.ca
midcall-signaling passthru
no call service stop
dial-peer voice 2 voip
destination-pattern [2-9]..[2-9]......
session protocol sipv2
session target ipv4:184.75.215.146
dtmf-relay rtp-nte cisco-rtp sip-kpml sip-notify
codec g711ulaw
no vad
dial-peer voice 3 voip
destination-pattern 1[2-9]..[2-9]......
codec g711ulaw
no vad
dial-peer voice 4 voip
incoming called-number .
dtmf-relay cisco-rtp rtp-nte
codec g711ulaw
dial-peer voice 1 voip
destination-pattern *97
codec g711ulaw
no vad
dial-peer voice 98 voip
destination-pattern *98
codec g711ulaw
no vad
dial-peer voice 56 voip
huntstop
destination-pattern 6135182156
session target ipv4:10.10.153.1:2000
codec g711ulaw
no vad
dial-peer voice 57 voip
huntstop
destination-pattern 6135182157
codec g711ulaw
no vad
sip-ua
credentials username 218332_main password 7 xyz realm toronto7.voip.ms
authentication username 218332_main password 7 xyz realm toronto7.voip.ms
mwi-server dns:toronto7.voip.ms expires 160 port 5060 transport udp unsolicited
registrar dns:toronto7.voip.ms expires 300
telephony-service
max-ephones 42
max-dn 144
ip source-address 10.10.153.1 port 2000
service dss
cnf-file location flash:
load 7914 S00105000400
load 7915-12 cmterm-7915.1-0-4-2
load 7915-24 cmterm-7915.1-0-4-2
load 7941 SCCP41.9-4-2SR3-1S
load 7961 SCCP41.9-3-1SR4-1S
load 7962 cmterm-7942_7962-sccp.8-5-2
time-zone 12
voicemail *97
mwi relay
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 56 dual-line
number 6135182156 secondary 56
mwi-type both
ephone-dn 57 dual-line
number 6135182157 secondary 57
mwi-type both
ephone 56
mac-address 0000.0000.0000
mwi-line 1
button 1:56
ephone 57
mwi-line 1
button 1:57
Router#show sip register status
Line peer expires(sec) registered P-Associ-URI
218332_main -1 180 yes
56 20002 69 no
57 20004 98 no
6135182156 20001 67 no
6135182157 20003 98 no
Router#debug ccsip error
SIP Call error tracing is enabled
Router#
*Jan 10 02:34:53.091: //389/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Cod e Class 4xx Method Code 100 received for REGISTER
*Jan 10 02:34:53.091: //389/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RP CB
Router#debug ccsip messages
SIP Call messages tracing is enabled
Router#
*Jan 10 02:37:24.991: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:toronto7.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.30:5060;branch=z9hG4bK31221BC
To: <sip:57@toronto7.voip.ms>
Date: Wed, 10 Jan 2018 02:37:24 GMT
Call-ID: D81E7D81-F4CD11E7-8006F9D3-51DFE151
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1515551844
CSeq: 174 REGISTER
Contact: <sip:57@192.168.1.30:5060>
Expires: 300
Supported: path
Content-Length: 0
*Jan 10 02:37:25.015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.30:5060;branch=z9hG4bK313244D
From: <sip:6135182157@toronto7.voip.ms>;tag=9F268C-1C97
To: <sip:6135182157@toronto7.voip.ms>
Date: Wed, 10 Jan 2018 02:37:25 GMT
Call-ID: D7D98654-F4CD11E7-8005F9D3-51DFE151
Max-Forwards: 70
Timestamp: 1515551845
CSeq: 174 REGISTER
Contact: <sip:6135182157@192.168.1.30:5060>
Expires: 300
Supported: path
Content-Length: 0
*Jan 10 02:37:25.035: //395/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.1.30:5060;branch=z9hG4bK31221BC;received=23.233.25.247;rport=56623
To: <sip:57@toronto7.voip.ms>;tag=as494c8bb2
CSeq: 174 REGISTER
Server: voip.ms
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="toronto7.voip.ms", nonce="1b827133"
Content-Length: 0
*Jan 10 02:37:25.039: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.30:5060;branch=z9hG4bK3141FB9
Max-Forwards: 70
CSeq: 175 REGISTER
Expires: 300
Authorization: Digest username="218332_main",realm="toronto7.voip.ms",uri="sip:toronto7.voip.ms:5060",response="717b01f4041b2e04c7f60216c621cf02",nonce="1b827133",algorithm=MD5
Content-Length: 0
*Jan 10 02:37:25.047: //396/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.1.30:5060;branch=z9hG4bK313244D;received=23.233.25.247;rport=56623
To: <sip:6135182157@toronto7.voip.ms>;tag=as195bacdf
CSeq: 174 REGISTER
Server: voip.ms
WWW-Authenticate: Digest algorithm=MD5, realm="toronto7.voip.ms", nonce="6950e0a7"
Content-Length: 0
*Jan 10 02:37:25.051: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.30:5060;branch=z9hG4bK31511A3
Max-Forwards: 70
CSeq: 175 REGISTER
Expires: 300
Authorization: Digest username="218332_main",realm="toronto7.voip.ms",uri="sip:toronto7.voip.ms:5060",response="35caef264994ae2c46363f633b8b2e56",nonce="6950e0a7",algorithm=MD5
Content-Length: 0
*Jan 10 02:37:25.067: //395/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
Via: SIP/2.0/UDP 192.168.1.30:5060;branch=z9hG4bK3141FB9;received=23.233.25.247;rport=56623
CSeq: 175 REGISTER
Server: voip.ms
Content-Length: 0
*Jan 10 02:37:25.083: //396/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.1.30:5060;branch=z9hG4bK31511A3;received=23.233.25.247;rport=56623
CSeq: 175 REGISTER
Server: voip.ms
Content-Length: 0
Solved! Go to Solution.
01-15-2018 01:53 AM
Issue is related to NAT please check your firewall or NAT device.
Received:
INVITE sip:6135180480@198.251.62.14:57276 SIP/2.0
Via: SIP/2.0/UDP 184.75.215.146:5060;branch=z9hG4bK70f089fb;rport
Max-Forwards: 70
From: "OTTAWA, ON" <sip:6135588702@184.75.215.146>;tag=as7c72a645
To: <sip:6135180480@198.251.62.14:57276>
Contact: <sip:6135588702@184.75.215.146:5060>
INVITE is being received from public IP to private IP and router is not able to handle it.
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
To: <sip:6135180480@198.251.62.14:57276>;tag=6C4831CC-72D
Date: Sat, 13 Jan 2018 16:34:44 GMT
Please work with your network team to configure the correct NATing.
Balram
01-10-2018 04:12 AM
01-10-2018 01:23 PM - edited 01-13-2018 08:49 AM
01-15-2018 01:53 AM
Received:
Max-Forwards: 70
Sent:
Balram
