Incoming SIP calls ITSP have 2 second delay before audio cut-through
dino55088
hi,
have ITSP-CUBE-CUCM (mtp required)- uccx agent
Incoming calls from ITSP have a slight 1-2 second before audio cut thru to uccx agent. External caller cannot hear our agents say "hello welcome to company xyz""
I believe this may be related to PRACK but i am not sure where I should enable it. On CUCM sip profile?
Leonardo Santana
To enable PRACK check this link:
https://www.cisco.com/c/en/us/support/docs/voice/session-initiation-protocol-sip/116086-configure-cube-cucm-sip-00.pdf
When you call to your IVR the PSTN user cannot hear the audio of IVR?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
hi Leonardo,
thanks for the doc link.
Yes the users can eventually hear one other but there is like a 2 second delay from the time the internal user/agent answers the call to the time audio is heard at the exernal party.
i.e. the internal user/agent has to repeat their greetiting or wait a second or 2 before saying hello.
I am just unsure which call leg i should enable PRACK
Do you have early media enabled at CUBE or at ITSP side?
Leonardo Santana
Leonardo Santana
ITSP sends us SIP EO inbound
