Incomplete NAT output
timothyquito
Can somebody has the same issue? we get an incomplete NAT translation from our router.
We're using NAT with voice traffic.
See below sample translation
MMR74.SFOK# show ip nat translations
Pro Inside global Inside local Outside local Outside global
--- 172.24.103.209 10.0.8.132 --- ---
--- 172.24.103.194 10.0.100.9 --- ---
--- 172.24.102.217 10.0.100.10 --- ---
--- 172.24.102.199 10.0.101.143 --- ---
tcp 172.24.103.39:58180 10.0.204.67:58180 38.107.71.35:2266 38.107.71.35:2266
--- 172.24.103.39 10.0.204.67 --- ---
--- 172.24.102.64 10.0.204.156 --- ---
--- 172.24.103.8 10.0.204.174 --- ---
tcp 172.24.102.214:55088 10.0.207.33:55088 198.105.200.65:62124 198.105.200.65:62124
tcp 172.24.102.214:55144 10.0.207.33:55144 198.105.200.65:62124 198.105.200.65:62124
tcp 172.24.102.214:55153 10.0.207.33:55153 198.105.200.65:62124 198.105.200.65:62124
tcp 172.24.102.214:55178 10.0.207.33:55178 198.105.200.65:62124 198.105.200.65:62124
--- 172.24.102.214 10.0.207.33 --- ---
tcp 172.24.103.35:63029 10.0.207.39:63029 38.107.71.35:2266 38.107.71.35:2266
tcp 172.24.103.35:63030 10.0.207.39:63030 38.107.71.11:2230 38.107.71.11:2230
tcp 172.24.103.35:63034 10.0.207.39:63034 38.107.71.35:2266 38.107.71.35:2266
tcp 172.24.103.35:63035 10.0.207.39:63035 38.107.71.35:2266 38.107.71.35:2266
tcp 172.24.103.35:63036 10.0.207.39:63036 38.107.71.35:2266 38.107.71.35:2266
--- 172.24.103.35 10.0.207.39 --- ---
--- 172.24.103.79 10.2.7.1 --- ---
--- 172.24.103.199 10.2.10.9 --- ---
--- 172.24.102.99 10.2.10.10 --- ---
--- 172.24.102.48 10.2.18.13 --- ---
--- 172.24.102.164 10.2.59.64 --- ---
tcp 172.24.102.169:50930 10.2.59.65:50930 38.107.71.35:2266 38.107.71.35:2266
Kasiraman S
Its not incomplete entry. Static NAT translation in the Running-config shows like that in NAT translation table.
Example:
ip nat inside source static 10.10.10.4 172.16.6.14
router# show ip nat translation
--- 172.16.6.14        10.10.10.4         ---                ---
Kasi
