Incorrect time on IP phones
Orkhan Gasimov
Recently, all Cisco IP phones started displaying incorrect time: they are 1 hour ahead of the time displayed on the CME router.
E.g. when debugging a 7942 phone using "debug ephone detail mac-address", the output shows:
Mar 28 12:46:13.850: ephone-20[19/7]:TimeDateReqMessage
Mar 28 12:46:13.850: year=2018 month=3 day=28
Mar 28 12:46:13.850: hour=16 minute=46 second=13
Mar 28 12:46:13.850: day=3 dayofyear=87 tzoffset=14400
However, the phone displays 17:46.
Some relevant router configs:
clock timezone Baku 4 0
telephony-service
  olsontimezone Asia/Baku version 2014c
  time-zone 34
  time-format 24
  date-format dd-mm-yy
voice register global mode cme olsontimezone Asia/Baku version 2014c time-format 24 date-format D/M/Y
The output of "show clock" also displays correct time.
Please help.
Thank you.
2 Accepted Solutions
R0g22
I checked and the timezone 34 takes into account daylight as well. Baku timezone does not experience daylight. Configured "time-zone 35" and remove olson. Do a create cnf-files and reset the phone.
Thanks for the input, really helpful.
I did the following under "telephony-service":
 - changed the timezone from 34 to 35;
 - removed olson;
 - did a "create cnf-files".
Then I rebooted a 7942 phone, and it displayed correct time. No need for reset.
I also did the following under "voice register global":
 - changed the time-zone from 34 to 35;
 - removed olson;
 - did a "create profile".
Then I rebooted a 3905 phone, and it displayed icorrect time (UTC).
So I added back the olson command like this:
olsontimezone Asia/Dubai version 2014c
did another "create profile", and rebooted the phone again. This time it worked.
R0g22
 - removed olson;
 - removed olson;
Glad it helped!
