Informacast HA
rahiable
Level 5
Level 5
Does the Informacast solution provide HA capabilities in an active/active or active/standby mode using 2 servers?
Thanks.
brad.jungemann
InformaCast supports the use of virtualization as more of a active/passive standby with VMWARE ESX. The second option for the server is a cold spare, the issue that we deal with for InformaCast is the limitation of the single Authentication URL for the Cisco IP Phones. If the primary authentication URL is not available there is not a good way for it to fail to a second IP address.
Thanks Brad, for the clarification. Is there any documentation on the active/passive mode? What are the requirements for installing and configuring the passive server? ie. same IP address as the primary etc..
Thanks.
Please contact me directly at brad.jungemann@singlewire.com and I have a document to share with you.
-Brad
