Hi All,does CCA support CME? i know it supports UC500, I am trying to connect to CME by CCA, it keeps asking username and password.thanksAlex
Using Service Statistics Monitor 1.0Under Views > Reports > I click a report and get "No Data Available", then in red below it "No Monitor Elements to report on".My SSM Agent is green to CUOM/CUSM. The status shows success. My CUOM has data from Call...
We have a dual core network. All access and distribution switches have dual uplinks to the core switches. One uplink port will be blocked by STP at any given time. Can you configure NIC Teaming on CUCM 7.x and above and configure one NIC in one switc...
Hi, My company is installing CME and CUE to 8 remote sites, overseas. I will have technicians onsite that have basic router experience. My question is, how difficult is it to install CME and CUE remotely if I was to give them the script where they ha...
Hi,When you try to generate bill report in PDF format, you can see via Acrobat reader application.But when you try it in CSV format, you can not see it via MS-Excel but only IE.Could anyone tell me why?My customer would like to look bill reports via ...
I need to upgrade CCM5 to CCM7I tried to backup the server, somebody added network device as SFTP before I need to chage the IP for the backup device but I could not. if I change the IP address, path, username and password then press save the old IP,...
Hi, I have a CUCM 4.2.(1) running in a MCS server this server is the Publisher of the Cluster, and I have a new server MCS and I would like use this new server as Publisher. What I need to back up all configurartion of the Publisher? Running the Cisc...
I *must* be missing something, because this should be EASY!!I have this building, outside phone # 555-1212. When someone calls that line, it rings internally extensions 1900,1901,1902,1903. These are part of Bldg3-LG (building 3 line group).A person...
Hi All, I have a UC500 Installation with Cisco CME and Cisco Unity Express Version 7.0. I have a shared main line and we are looking for a solution to check and delete voice messages via outlook express our outlook 2003 or 2007. Currently we have not...
Hi,Does any one know how to add certificates in CUCM 6.1?Requirement: I need to add the secured SIP trunk between CUCM & Exchange server. If not wrong CUCM need to trust Exchange server so we need to add certificates to the CUCMRegds,Navin Golani
Hi,One of my customer is having problem with intermittent voice disconnection issue on CME. The customer has two location and both locations are connected via site to site VPN. Sometimes internal call between two location is getting disconnected afte...
I have a large IPT deployment (CUCM 6.1) with 600 IP phones and 400 analog devices. The analog devices mostly consist of Aastra analog phones hung off of 25 VG224s. All phones are configured as SCCP, including the Aastra analog end-points on the VG22...
Hello all.I'd like to know if you can give me some advices on how to configure an overlapping dialplan on ccmei have ccme 7.0 and an overlapping dialplan with extensions 5XXX and 57XXXXhow could i configure both to workthanksCris
We are monitoring our agents calls from time to time and everything was working up until yesterday when we swapped their 7960 phones out and gave them 7965 phones. Now you get a error message from the supervisor desktop and can no longer monitor thei...
Hello Netpros....I have a 3 server cluster of IBM MCS 7835s running CUCM 7.1.3. Each server takes just under 30 minutes to do a full restart. The servers POST quickly...it's the CUCM services that seem to take a long time to start. Has anyone else ex...
Subject | Author | Posted |
06-05-2025 02:29 PM | ||
05-29-2025 01:49 AM | ||
05-23-2025 02:08 PM | ||
05-22-2025 11:54 PM | ||
05-21-2025 06:23 AM |
User | Count |
6 | |
3 | |
3 | |
2 | |
1 |
