Inherited IP phone system - need to connect to CallManager GUI
TURBOxSPOOL
Hello all,
First, a disclaimer: I am a complete and utter newbie with Cisco IP phones and networking. I was given the task of picking up the pieces where those before me left off, and I have nothing but access to routers. No documentation, nada. I only know what I can interpret from the router configs.
EDIT: so the main problem is that this auto-attendant isn't working. I dial 298 and all I get is a busy signal. "The guy before me" said he had a ticket open with Cisco because he had errors when he tried to configure it. Unfortunately he left and I was asked to fix everything. I can learn what I don't know, but hopefully you can help me make this process a little more simple.
So, I can log into the service module which is where the Cisco callmanager software  is (should be) installed. I can see the configuration for the auto-attendant (which is what I need to fix). I want to be able to use the Cisco GUIs to configure this.
Also, part of the configuration points to an attendant script:
script "aasimple.aef"
How can I launch the script editor to view/edit this script? Also, where is the file even located?
Will I need physical access to the module?
Here is the running config from the service module (with some info omitted):
clock timezone America/New_York
hostname se-100-1-21-10
ip domain-name unspecified
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/hsEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35jwAAAAA="
groupname Administrators create
groupname Broadcasters create
groupname Administrators member admin
groupname Administrators privilege superuser
groupname Administrators privilege ManagePrompts
groupname Administrators privilege ManagePublicList
groupname Administrators privilege ViewPrivateList
groupname Broadcasters privilege broadcast
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/VNXHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35jwAAAAA="
calendar biz-schedule systemschedule
open day 1 from 00:00 to 24:00
open day 2 from 00:00 to 24:00
open day 3 from 00:00 to 24:00
open day 4 from 00:00 to 24:00
open day 5 from 00:00 to 24:00
open day 6 from 00:00 to 24:00
open day 7 from 00:00 to 24:00
end schedule
ccn application autoattendant
description "autoattendant"
enabled
maxsessions 8
parameter "allowExternalTransfers" "false"
parameter "BusinessOpenPrompt" "AABusinessOpen.wav"
parameter "MaxRetry" "3"
parameter "BusinessClosedPrompt" "AABusinessClosed.wav"
parameter "PlayExtensionsPrompt" "AASPlayExtensions.wav"
parameter "HolidayPrompt" "AAHolidayPrompt.wav"
parameter "WelcomePrompt" "AAWelcome.wav"
parameter "BusinessSchedule" "systemschedule"
parameter "ExtensionLength" "1"
end application
ccn application ciscomwiapplication
description "ciscomwiapplication"
enabled
maxsessions 8
script "setmwi.aef"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
parameter "CallControlGroupID" "0"
end application
ccn application promptmgmt
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
end application
ccn application voicemail
description "voicemail"
enabled
maxsessions 8
script "voicebrowser.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn subsystem jtapi
ccm-manager address 0.0.0.0
end subsystem
ccn subsystem sip
gateway address "100.1.21.1"
end subsystem
ccn trigger sip phonenumber 297
application "promptmgmt"
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 298
application "autoattendant"
enabled
maxsessions 8
end trigger
ccn trigger sip phonenumber 299
application "voicemail"
enabled
maxsessions 8
end trigger
voicemail default mailboxsize 21120
voicemail broadcast recording time 300
end
I apologize for the hastily written post, but I am under pressure to get things working. I was just hoping some of the experienced users can give some detailed advice which will allow me to quickly get on the right track.
Thanks for reading!
7 Replies 7
keanej
Level 3
Level 3
Where do I start with this one !!!
Firstly lets explain what you have here -(as I imagine it!)
You have a switch with a number of phones -
You have a router running Call Manager Express
You have a Module (I'm guessing NM-CUE) as you have 8 session available.
Your prompt management is on 297
Your Auto Attendent is on 298
Your Voicemail is on 299.
Are 297 and 299 working ??
The script is edited using a CUE Script editor. You need to know what version of module (Show Software Version).
I would recommend taking the sample script - aasample.aef - but I'd imagine its been hacked a little now !
Let me know what version you are on - I can help you get started -
Where to start indeed! Thanks for bearing with me!
297 + 299 seem to work just fine.
Here are the software versions:
se-100-1-21-10> show software version
Installed Packages:
- Installer  2.1.3
- Bootloader (Primary)  2.1.2
- Infrastructure  2.1.3
- Global  2.1.3
- GPL Infrastructure  2.1.3
- Voice Mail  2.1.3
- Bootloader (Secondary)  2.1.2
- Core  2.1.3
- Auto Attendant  2.1.3
Installed Languages:
- English language pack  2.1.3
I can pick up on things rather quickly, however the sheer volume of information on cisco networking devices making getting into things rather difficult. I was able to reconfigure a number of phones so I hope I can get this done.
Thanks for looking!
What I would recommend is to install a simple script.
Now the editor I have included is for version 3 - unfortunately you are on version 2 (SORRY This forum doesnt allow exe files !)
The version you are on is one of the earliest versions I have seen - its about 6 years old. I would strongly recommend upgrading to version 7.0.6, which is about as far as you can go with that hardware. To upgrade the module you need a FTP server and TFTP server reachable from the router (your PC) - and download a few files & Licenses.
Anyway - back to your problem. I believe this sample script should work fine (just to get you going)
Basically the way it works is - you 'callin' to an auto attendent number - this 'application' has a script associated with it.
The script will have a number of parameters (which need to be valid)
To get going - upload the aa_sample1.aef into your module - goto scripts and upload
then go into auto attendant - and change the script from the current one to this sample one - correct any invalid parameters.
Now you should at least hear something from the auto attendent.
You need to use the editor to create a new script - you can butcher the sample if you like (just save it as something else!)
To get the editor - you need to goto
Download Software | Voice and Unified Communications | Unified Communications Applications | Voicemail and Unified Messaging | Cisco Unity Express | Cisco Unity Express Version 2.3.1
Its stored there !
Wow, I must say I really appreciate your response. Thanks very much.
Anyway, I have been side-tasked for the last day or so, but I am about to try your suggestions right now. I'll report back with the results.
Thanks again!
Ok, having trouble uploading the script. I posted this in a similar discussion:
https://supportforums.cisco.com/message/3245809#3245809
I have an http server running on my local lan, and I want to copy in the script from there.
se-100-1-21-10> ccn copy url "http://172.16.2.253/storage/aa_sample1.aef" script "aa_sample1.aef"
(7) Connect failed; Success
Any ideas? Apparently I can't even ping the server:
se-100-1-21-10> ping 172.16.2.2
PING 172.16.2.2 (172.16.2.2) 56(84) bytes of data.
64 bytes from 172.16.2.2: icmp_seq=1 ttl=255 time=0.385 ms
64 bytes from 172.16.2.2: icmp_seq=2 ttl=255 time=0.268 ms
64 bytes from 172.16.2.2: icmp_seq=3 ttl=255 time=0.228 ms
64 bytes from 172.16.2.2: icmp_seq=4 ttl=255 time=0.227 ms
64 bytes from 172.16.2.2: icmp_seq=5 ttl=255 time=0.225 ms
--- 172.16.2.2 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 1ms
rtt min/avg/max/mdev = 0.225/0.266/0.385/0.063 ms, ipg/ewma 0.378/0.323 ms
se-100-1-21-10> ping 172.16.2.253
PING 172.16.2.253 (172.16.2.253) 56(84) bytes of data.
--- 172.16.2.253 ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4030ms
, ipg/ewma 1007.628/0.000 ms
se-100-1-21-10>
The router where CUE is has the 172.16.2.2 ip address, the server is 172.16.2.253.
Any ideas on why I can't connect to something on the local lan? Will I need physical access to the module or something? Can the router be configured to allow traffic on the local LAN?
Thanks for all the help!
Ok, I got the script loaded.
I had to move the service module to a different network in order to be able to upload the script, but I was able to get the script copied.
After resetting the original configuration, I modified the "autoattendant" application to use the new script:
se-100-1-21-10(config)> ccn application autoattendant
Modifying existing application
se-100-1-21-10(config-application)>  description "autoattendant"
se-100-1-21-10(config-application)>  enabled
se-100-1-21-10(config-application)>  maxsessions 8
se-100-1-21-10(config-application)> script "aa_sample.aef"
end application
Application created successfully, but might not be fully functional due to internal errors
Obviously there is still a problem, and I don't get anything when trying the auto-attendant (298). I am now trying to reload the configuration....
A couple of things -
You should be able to hit the GUI for the service module.
Turn off the proxy server for you PC and try to hit the address of the service module.
You need something similar to below to get working
int gig 0/1
ip address 192.168.10.1 255.255.255.0
no shut
! This interface needs to be up
interface Service-Engine1/0
ip unnumbered GigabitEthernet0/1
service-module ip address 192.168.10.8 255.255.255.0
service-module ip default-gateway 192.168.10.1
ip route 192.168.10.8 255.255.255.255 Service-Engine1/0
! I also add the following time-savers
alias exec cue-status service-module service-Engine 1/0 status
alias exec cue-shut service-module service-Engine 1/0 shut
alias exec cue-sess service-module service-Engine 1/0 sess
alias exec cue-reset service-module service-Engine 1/0 reset
if you still have no joy geting to the web gui
you should seriously consider the upgrade
To upgrade add an FTP and TFTP server to your PC,at C:\upload
now add a user to you ftp server -
Username: CISCO
password: password
Ser the root folder for this user to
c:\upload
Now goto the Cisco Website and download the following files
CUCE-Editor-Installer-7.0.3.exe
cue-installer.nm-aim.7.0.3
cue-vm-en_US-langpack.nm-aim.7.0.3.prt1
cue-vm-full-k9.nm-aim.7.0.3.prt1
cue-vm-installer-k9.nm-aim.7.0.3.prt1
cue-vm-k9.nm-aim.7.0.3.pkg
cue-vm-langpack.nm-aim.7.0.3.pkg
cue-vm-license_100mbx_ccm_7.0.3.pkg
cue-vm-license_100mbx_cme_7.0.3.pkg
cue-vm-license_12mbx_ccm_7.0.3.pkg
cue-vm-license_12mbx_cme_7.0.3.pkg
cue-vm-license_25mbx_ccm_7.0.3.pkg
cue-vm-license_50mbx_ccm_7.0.3.pkg
cue-vm-license_50mbx_cme_7.0.3.pkg
Place these files in the upload directory -
Now go to the command line and reset the module.
key ***
during the reboot -
upload the installer file
When prompted load the package
cue-vm-k9.nm-aim.7.0.3.pkg.
Using the GUI you can setup the module again - its really simple
You can now use the
to make your scripts.
