installation failure-CUCM 8.6.2 on MCS7845i3
CSCO10936521
Hello.
I was trying to install CUCM 8.6.2 on MCS7845I3 server with correct memory and disk,good battery, up-to-date server firmware, but keep getting this error
"Critical Error
The hardware you are using is not supported for this product.
Installation will now halt".
Can anyone please maybe advise me what could be the reason? I believe I'm using a good bootable DVD which was from Cisco originally.
Thank you so much for your kind advice in advance.
7 Replies 7
Jaime Valencia
What's the exact server model??? 7845-I3 is just the family, not the exact model.
java
if this helps, please rate
Thank you for your reponse
i think it is 7947PAQ
Nope, something like IPC1, IPC2, CMC2, CMD1, etc.
java
Oh, then CMC2
How much RAM and HDD does it have??
java
I think it's 6g ram and 160g x4 of hdd. Can't remember the exact number though...
you can run the commands show memory size , show memory count and show hardware from CLI.
regds,
aman
