Installing CUCM 8.6 on VM Ware
Virstra001
Hello Friends,
Our company is thinking on installing CUCM 8.6 on VM Ware.
We wanted to explore CUCM 8.6 availability on Virtual  Platform
  • VCE
  • Dell
  • HP
  • IBM
  • Any  other
Can someone guide us as to which platform should we go with and how do we go about it (Installation and configuration).
If anyone has a guide for the same would be grate if you could share it.
Thanks and Regards,
Sargam Patne
8 Replies 8
Dennis Mink
Cisco UCS's for Voice are rebranded HP servers.
Please remember to rate useful posts, by clicking on the stars below.
Hello Friend,
Thanks for your help...
Can you please confirm if the below link is the correcr link to get the info...
http://docwiki.cisco.com/wiki/Unified_Communications_VMware_Requirements
Sargam Patne
Hi Sargam,
The link which you have given is is maintained by Cisco and is 100% correct link for the details. It has all the information regards to Cisco collobaration product on Virtulization platform.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ronpatel
Level 8
Level 8
HI
Below link shows you the support policy of the third party servers.
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware
Please note :- To use third party hardware for UC installation , the third party hardware should satisfy all the requirement mentioned in the link provided above.
Ronak Patel
Hello Ronak,
Thanks for your support as always.
The above link will surely be of help...
Buddy just wanted to know the basic difference between CUCM on VMware and UCS....or is it the same?
Sargam Patne
Hi ,
Vmware ( ESXi ) is required for virtulization. And UCS is Hardware.
CUCM on Vmware means , you will install ESXi (Vmware) hypervisor on UCS ( Hardware server just like other servers ) and install CUCM application over this ESXi.
Please rate all helpful post by clicking stars below the answer.
Ronak Patel
Hello Ronak,
Thanks for the prompt reply..
So if in case we are planning to install CUCM on VMware then we will have to first procure a UCS server, install the VMware ESXi on it and then install the CUCM on the VMware.......correct me if I am wrong.
Plus can you help me with the hardware specs required for the same.
Sargam Patne
Hello Ronak,
Also would appreciate if you let us know about the UCS hardware vendor...
Like in MCS servers only IBM and HP manufacture the hardware.....similarly for UCS how many different manugfacturers ar there?
Sargam Patne
