04-20-2012 08:06 AM - edited 03-16-2019 10:44 AM
What am I doing wrong?? This installation is baffling me.
04-20-2012 09:14 AM
Loading tftp://172.16.222.1/cue-installer.SPA.sme.8.6.1 ... TFTP error 1 (No such file)
ypu are missing that, use "complete installation file set"
04-20-2012 09:24 AM
Looks like I was missing the language pack. Would have thought that was included in the "complete installation file set"..
04-20-2012 09:34 AM
It is not.
Please remember to rate useful posts clicking on the stars below.
04-20-2012 10:54 AM
My next problem.. However..
Looks like Unity Express installed fine and brought me to a CLI configuration wizard.. I created use admin password admin in group Administrators.. I can't get the GUI to load in a browser though..
I can ping the IP from my pc.. I can access CM Express fine.. In some of the configuration and installation guides it mentions .html files on the flash. I don't see any of them..
04-20-2012 11:19 AM
Well.. Now its suddenly working as well.. Not sure on that one..
When going through the initial configuration i'm getting logon failed though..
Ive verified web admin username and password to no avail.
04-20-2012 11:46 AM
Check that you're connecting to CUE address as opposed to CME address.
04-20-2012 12:44 PM
I have the gui working.. When I try to enter the web admin username and password and CUCME ip address it tells me login failed. I'm using the same username and login as call manager express..
Also issued this command under telephony-services:
web admin system name USERNAME password PASSWORD
It just doesn't login.. Again.. Another small step and another boundry..
04-20-2012 01:15 PM
That is because you're using the wrong URL for CME, as indicated in product documentation, or in many thread similar to this.
04-20-2012 01:18 PM
I'm in the Cicso Unity Express... I am logged into it.. I have both pulled up.. I have all my option for mailboxes, etc.. The problem seems to be control of the CUME.. It doesn't like my username and password.. Maybe I am saying all this wrong.
04-20-2012 01:56 PM
This is what I am getting.. I uninstalled unity express and reinstalled..
Thanks.
04-22-2012 04:19 AM
I know that it sound obvious, but if CUE can't access CME, it means something is configured wrong.
Anyway, that is not needed for CUE to work normally.
Thanks for the nice rating and good luck!
04-23-2012 11:39 AM
Thats my problem.. I don't know whats configured wrong. I set the web admin username and password myself so I am confused.
04-23-2012 12:23 PM
Maybe in cme, maybe in cue. With patience, study it more, eventually you will find out, and laugh about.
